Is there a case when an object is declared without a call to the constructor? as in, for example:
ArrayList<Integer> grades;
Or is it always the case that ArrayList<Integer> grades
(as in our example here) would always be followed by a call to a constructor as in,
ArrayList<Integer> grades = new ArrayList<Integer>();
If the latter is the case i.e. a declaration of an object is always followed by its initialization with a constructor then why isn't
already implies
Otherwise when is it the case that an object is declared without an immediate call to the constructor following it?
Is it the case that
can be initialized by anything other than
