Fields that are protected
are not hidden strongly enough for many static analysis tools such as sonar, pmd, or checkstyle. protected
fields are visible to subclasses (docs) and allow subclasses to change the state of the class without going through accessor methods which may cause problems in the methods of the superclass.
So, that's why its complaining about protected
fields. Unless you are specifically designing for extension (that the class should be subclassed), it is probably better to use the default package-private level for fields and methods that you want visible to tests (or other classes in the package).
Personally, I've never had use for a protected
variable field within a class - even those that are subclassed. protected final
fields occasionally, but never a variable field. On the other hand, I've often used default level on methods for testing and (more often than protected final
though still uncommon) /* default */ final
fields.
The purpose of the warning is to get you to think more about how you are actually presenting the class and the contract you are presenting to others for its use. If you have it be too permissive, it is all too easy for co-workers to take short cuts and tinker with the innards of the class (I once saw someone create an inner class that subclassed another class and create public methods to access the protected fields). Reducing the visibility of fields and methods can be a painful refactoring.
Start out with the most restrictive permissions and as you find real need for a design that is more permissive, open it up. This is what the static analysis tools are encouraging you to do.
