Because implicit type conversions are usually unsafe, and C++ takes a more safe stance to typing than C does.
C will usually allow implicit conversions, even if most chances are that the conversion is an error. That's because C assumes that the programmer knows exactly what they are doing, and if not, it is the programmer's problem, not the compiler's problem.
C++ will usually disallow things that could potentially be errors, and require you to explicitly state your intention with a type cast. That's because C++ is trying to be programmer-friendly.
You might ask how come it is friendly when it is actually requiring you to type more.
Well, you see, any given line of code, in any program, in any programming language, will generally be read many more times than it will be written (*). So, ease of reading is much more important than ease of writing. And when reading, having any potentially unsafe conversions stand out by means of explicit type casts helps to understand what is going on and to have a certain level of certainty that what is happening is in fact what was intended to happen.
Besides, the inconvenience of having to type the explicit cast is trivial compared to the inconvenience of hours upon hours of troubleshooting to find a bug which was caused by a mistaken assignment that you could have been warned about, but never were.
(*) Ideally it will be written only once, but it will be read every time someone needs to review it to determine its suitability for reuse, and every time there is troubleshooting going on, and every time someone needs to add code near it, and then every time there is troubleshooting of nearby code, and so on. This is true in all cases except for "write-once, run, then throw away" scripts, and so it is no wonder that most scripting languages have a syntax which facilitates ease of writing with complete disregard to ease of reading. Ever thought that perl is completely incomprehensible? You are not alone. Think of such languages as "write-only" languages.
