I'm setting up a data validator that will iterate through the rows of a spreadsheet, and for each column, perform a validation check. I was thinking that this might be an appropriate task for the Strategy Pattern as follows:
interface IValidator:
public function isValid(rng as range) as boolean
end function
implementation validator_Number:
'checks whether or not value is a number
implements IValidator
public function IValidator_isValid(rng as range) as boolean
IValidator_isValid=isnumeric(rng.value)
end function
implementation validator_Capitalized:
'checks whether all letters are capitalized in value
IValidator_isValid=isnumeric(rng.value) and (ucase(rng.value)=rng.value)
end function
validation checker:
'iterates through worksheet cells, validating them and
public sub validationChecker()
dim headerRow as long
dim validator as IValidator
headerRow=1
for row=2 to maxRow
for column=1 to maxColumn
'check the column header name and instantiate
'validator using the appropriate implementation
select case sheet.cells(headerRow,column).value
case "NAME"
set validator=new validator_Capitalized
case "AGE"
set validator=new validator_Number
'etc.
end select
if validator.isValid(sheet.cells(row,column)) then
doSomething()
endif
next
next
I previously asked another question about using Strategy to validate Excel data, and the response was that I didn't need to do that because there were only a few types of tests and so the rules could be held in a data store. But here there are going to be many different kinds of validation tests, some of which have several lines of code. Is the Strategy implementation that I outlined above the most appropriate pattern to use here?
