18
I've learned C# over the course of the past six months or so and am now delving into Java. My question is about instance creation (in either language, really) and it's more of: I wonder why they did it that way. Take this example
Person Bob = new Person();
Is there a reason that the object is specified twice? Would there ever be a something_else Bob = new Person()?
It would seem if I were following on from convention it would be more like:
int XIsAnInt;
Person BobIsAPerson;
Or perhaps one of these:
Person() Bob;
new Person Bob;
new Person() Bob;
Bob = new Person();
I suppose I'm curious if there's a better answer than "that's just the way it is done".
Peter Mortensen
  • 1,050
  • 26
    What if Person is a subtype of `LivingThing` ? You could write `LivingThing lt = new Person()`. Look for [inheritance](http://en.wikipedia.org/wiki/Inheritance_%28object-oriented_programming%29) and interfaces. – xlecoustillier Feb 07 '15 at 19:55
    `Person Bob` declares a *variable* of type "reference to `Person`" called `Bob`. `new Person()` creates a `Person` object. *References, variables and objects are three different things!* – user253751 Feb 08 '15 at 01:48
    Possibly worth noting is that VB.Net does have a combined declaration and initialisation syntax. The direct equivalent of `Person Bob = new Person()` is `dim Bob As Person = new Person` but can also do `dim Bob As new Person()` which combines two stages. – user1937198 Feb 08 '15 at 12:25
    Are you annoyed by the redundancy? Then why not write `var bob = new Person();`? – 200_success Feb 08 '15 at 18:19
    `Person Bob();` is possible in C++ and means nearly the same thing as `Person Bob = Person();` – flaviut Feb 08 '15 at 18:34
    @user60561 no, it declares a function taking no arguments and returning Person. – Nikolai Feb 09 '15 at 08:42
  • @user60561: Incorrect. – Lightness Races in Orbit Feb 09 '15 at 10:34
  • @Nikolai @Lightness Races in Orbit Good point, I suppose it's obvious I don't use C++ much. `Person Bob(1);` would be correct though. – flaviut Feb 10 '15 at 00:08
7 Answers7
52
Yes, because of inheritance. If:
public class StackExchangeMember : Person {}
Then:
Person bob = new StackExchangeMember();
Person sam = new Person();
Bob is a person too, and by golly, he doesn't want to be treated differently than anyone else.
Further, we could endow Bob with super powers:
public interface IModerator { }
public class StackOverFlowModerator : StackExchangeMember, IModerator {}
IModerator bob = new StackOverFlowModerator();
And so, by golly, he won't stand for being treated any differently than any other moderator. And he likes to sneak around the forum to keep everyone in line while incognito:
StackExchangeMember bob = new StackOverFlowModerator();
Then when he finds some poor 1st poster, he throws off his cloak of invisibility and pounces.
((StackOverFlowModerator) bob).Smite(sam);
And then he can act all innocent and stuff afterwards:
((Person) bob).ImNotMeanIWasJustInstantiatedThatWay();
Tarik
radarbob
  • 5,808
    This would be a lot clearer if you lower-cased your object names. – Lightness Races in Orbit Feb 08 '15 at 18:49
  • 38
    Good example of the specification; bad example of inheritance. To anyone else reading this, please, don't try to solve user roles using inheritance. – Aaronaught Feb 08 '15 at 19:01
    @Aaronaught is correct. Don't create separate classes for different types of people. Use a bitfield `enum`. – Cole Tobin Feb 08 '15 at 19:42
    @Aaronaught It's all very well saying what not to do, but it's not very helpful without saying what people should do instead. – Pharap Feb 08 '15 at 23:45
  • @Pharap the problem with using classes for user roles is that users can't change roles! Use a field `bool isModerator` instead, or similar. – user253751 Feb 09 '15 at 01:34
    @Pharap: I have done exactly that, in [several](http://programmers.stackexchange.com/a/216481/3249) [other](http://programmers.stackexchange.com/a/83968/3249) [questions](http://programmers.stackexchange.com/a/211487/3249). The simple answer is that users (authentication/identity) and security policy (authorization/permissions) should be treated as separate concerns, and the standard models for security policy are either role-based or claims-based. Inheritance is more useful to describe the object that actually does the authentication, e.g. an LDAP implementation and a SQL implementation. – Aaronaught Feb 09 '15 at 02:44
    @Aaronaught Thank you, this is precisely what I mean. The explanation and links you have provided in your second comment are certain to be much more useful to the unaware or inexperienced programmer than merely stating one method to be wrong. – Pharap Feb 09 '15 at 03:37
34
Let's take your first line of code and examine it.
The first Person is a type specification. In C#, we can dispense with this by simply saying
var Bob = new Person();
and the compiler will infer the type of the variable Bob from the constructor call Person().
But you might want to write something like this:
IPerson Bob = new Person();
Where you're not fulfilling the entire API contract of Person, but only the contract specified by the interface IPerson.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
    +1: I will do the `IPerson` example in my code to ensure I do not accidentally use any private methods when I'm writing code that should be copy/pastable to another `IPerson` implementation. – Cort Ammon Feb 07 '15 at 21:22
  • @CortAmmon I think you have a typo there, clearly you meant "work with polymorphism" rather than copy/pastable on that code :D – Benjamin Gruenbaum Feb 08 '15 at 16:42
  • @BenjaminGruenbaum sure, for some definition of polymorphism ;-) – Cort Ammon Feb 08 '15 at 18:01
  • @CortAmmon how would you accidentally call a _private_ method? Surely you meant `internal`? – Cole Tobin Feb 08 '15 at 19:43
  • @ColeJohnson either way. I wrote that thinking of a specific case that I run across where `private` is meaningful: factory methods that are part of the class being instantiated. In my situation, access to private values should be the exception, not the norm. I work on code which is going to long outlive me. If I do it this way, not only am I unlikely to use any private methods myself, but when the next developer copy/pastes this a few dozen places and the developer after that copies them, it decreases the odds that someone sees an opportunity to use private methods as "normal" behavior. – Cort Ammon Feb 08 '15 at 20:08
  • The idea is trying to weave business logic into the code: I'm trying to discourage a "quick turnaround deadline" from infecting the code. The more "good ideas" look like "cheap ideas," the healthier I can keep my code. – Cort Ammon Feb 08 '15 at 20:09
21
  1. This syntax is pretty much a legacy from C++, which, by the way, has both:
    Person Bob;
    and
    Person *bob = new Bob();
    The first to create an object within the current scope, the second to create a pointer to a dynamic object.
  2. You definitely can have something_else Bob = new Person()
    IEnumerable<int> nums = new List<int>(){1,2,3,4}
    You are doing two different thing here, stating the type of the local variable nums and you say you want to create a new object of the type 'List' and put it there.
  3. C# kind of agrees with you, because most of the time the type of the variable is identical to what you put in it hence:
    var nums = new List<int>();
  4. In some languages you do your best to avoid stating the types of variables as in F#:
    let list123 = [ 1; 2; 3 ]
AK_
  • 744
    It's probably more accurate to say that your second example create a pointer to a new Bob object. The way things are stored is technically an implementation detail. – Robert Harvey Feb 07 '15 at 22:41
    _"The first to create a local object on the stack, the second to create an object on the heap."_ Oh man, not this misinformation again. – Lightness Races in Orbit Feb 08 '15 at 18:50
  • @LightnessRacesinOrbit better? – AK_ Feb 08 '15 at 21:09
  • @AK_: Not bad though it's a shame my edit was rejected as it was perfect. – Lightness Races in Orbit Feb 09 '15 at 02:59
  • @LightnessRacesinOrbit honestly as a novice C++ developer, coming from mostly C# and a little C (no RAII) i found these terms pretty confusing. more importantly their names "automatic/ dynamic storage duration" don't imply what they really mean... – AK_ Feb 09 '15 at 09:21
    @AK_ While "dynamic" pretty much means "heap" (when heap is the memory model used by the platform), "automatic" is very distinct from "stack." If you do `new std::pair()`, then the members `first` and `second` of the pair have automatic storage duration, but they are probably allocated on the heap (as members of the dynamic-storage-duration `pair` object). – Angew is no longer proud of SO Feb 09 '15 at 10:06
    @AK_: Yes, those names imply _precisely_ what they mean, whereas this "stack" vs "heap" nonsense does _not_. That's the entire point. That you find them confusing only reinforces the need for us to teach them, so that you are not relying on inaccurate/incorrect terminology just because it's familiar! – Lightness Races in Orbit Feb 09 '15 at 10:29
There is a huge difference between int x and Person bob. An int is an int is an int and it must always be an int and can never be anything other than an int. Even if you don't initialize the int when you declare it (int x;), it is still an int set to the default value.
When you declare Person bob, however, there's a great deal of flexibility as to what the name bob might actually refer to at any given time. It could refer to a Person, or it could refer to some other class, e.g. Programmer, derived from Person; it could even be null, referring to no object at all.
For example:
  Person bob   = null;
  Person carol = new Person();
  Person ted   = new Programmer();
  Person alice = personFactory.functionThatReturnsSomeKindOfPersonOrNull();
The language designers certainly could have made an alternative syntax that would have accomplished the same thing as Person carol = new Person() in fewer symbols, but they still would have had to allow Person carol = new Person() (or make some strange rule making that particular one of the four examples above illegal). They were more concerned with keeping the language "simple" than in writing extremely concise code. That may have influenced their decision not to provide the shorter alternative syntax, but in any case, it wasn't necessary and they didn't provide it.
David K
  • 475
The two declarations can be different but are often the same. A common, recommended pattern in Java looks like:
List<String> list = new ArrayList<>();
Map<String, Integer> map = new HashMap<>();
These variables list and map are declared using the interfaces List and Map while the code instantiates specific implementations. This way, the rest of the code only depends on the interfaces and it's easy to pick a different implementation classes to instantiate, like TreeMap, since the rest of the code can't depend on any part of the HashMap API that's outside the Map interface.
Another example where the two types differ is in a factory method that picks a specific subclass to instantiate, then returns it as the base type so the caller needn't be aware of the implementation details, eg a "policy" choice.
Type inference can fix the source code redundancy. Eg in Java
List<String> listOne = Collections.emptyList();
will construct the right kind of List thanks to type inference and the declaration
static <T> List<T> emptyList();
In some languages, type inference goes further, eg in C++
auto p = new Person();
Jerry101
  • 5,367
In layman's words:
  • Separating declaration from instantiation helps decouple who uses the objects from who creates them
  • When you do that, polyporphism is enabled since, as long as the instantiated type is a subtype of the declaration type, all code using the variable will work
  • In strongly typed languages you must declare a variable stating its type, by doing simply var = new Process() you are not declaring the variable first.
Tulains Córdova
  • 39,201
  • 154
It's also about the level of control over what is happening. If the declaration of an object/variable automatically calls a constructor, for example, if
Person somePerson;
was automatically the same as
Person somePerson = new Person(blah, blah..);
then you'd never be able to use (for example) static factory methods to instantiate objects rather than default constructors, that is, there are times when you don't want to call a constructor for a new object instance.
This example is explained in Joshua Bloch's Effective Java (Item 1 ironically enough!)
Peter Mortensen
  • 1,050
