Could someone tell me whether the following is A) a good solution to the problem of repeating code and B) an example of the template method?
Let's say I have one table, named VEHICLES, which I use to store different types of vehicles (e.g. car, van, bus). I have a bunch of repository classes which should retrieve each type of vehicle:
class CarRepository{
public function getAll(){
$sql = "select * from vehicles where type='car'";
//some code to communicate with the database
class BusRepository{
$sql = "select * from vehicles where type='bus'";
As you can see, each repo has almost the same code in the getAll method, which isn't very DRY. I was thinking a better solution might be to have a common base class for the repos, like this:
abstract class VehicleRepository{
final public function getAll(){
$sql = "select * from vehicles where type='".$this->getType()."'";
echo $sql;
//code to communicate with the database
abstract function getType();
And then each repo would just need to define the getType method:
class CarRepository extends VehicleRepository{
public function getType(){
return "car";
class BusRepository extends VehicleRepository{
return "bus";
Does this seem reasonable? And is this what is meant by the template method pattern?
