I've got a job and many new things to be learned. The first thing is to understand big project, writtened mostly in C++, using Visual Studio. So, I see a statement, and I want to find its definition. Using Ctr+F to search through entire solution, and if multiple libraries have different function but same name, I would have many result that I don't know which one is the definition of the statement. And vice versal, I see a definition, but I don't know which statements are its invoker.
Is there any tips for my issue? Any suggestion is very appreciated. Thanks (And please, I don't want to go to debug mode, since It takes lot of time to build, and I'm lazy rofl).
  • Visual Studio has a "show definition" functionality. Try right-clicking on the name and look at the pop-up menu. I've witnessed problems with it, but it usually is better than using ctrl-F. – Sjoerd Jan 30 '15 at 04:52
You could try with a tool like doxygen.
I find it useful when I start to work on a new codebase.
Just tweak some parameter in the configuration file and run doxygen against your code. For your needs you could change:
  • CALL_GRAPH = YES. A graphical call graph is drawn for each function showing the functions that the function directly or indirectly calls
  • CALLER_GRAPH = YES. A graphical caller graph is drawn for each function showing the functions that the function is directly or indirectly called by
Probably also:
The nice things is that even if the documentation isn't already available, you can extract a lot of useful information (and while learning you could start documenting the code).
Anyway it takes time.
albert
  • 155
manlio
  • 4,166
  • 35
