I am thinking of a standard AJAX setup (JS<->PHP<->MySql).
I want to generate reports (charts, tables, etc) probably using at maximum a few dozen data points (certainly never over 1k).
I am unsure whether to download all data on initial page load and generate charts when the user changes a parameter - say start date for example - using JS totally on the client side or to send an AJAX request to the server & use PHP there to generate & return a chart.
What should I take into consideration?
- Is there a standard approach, or does it "depend"?
- Any considerations of performance with so little data? Security?
- Might client side be better if I want to export the reports?
- Does it just boil down to which ever free charting package looks good to me?
- For smart 'phones, can they readily generate charts responsively, or would it be better to download them as an image file form the server?
- I suppose that it also depends on whether I will allow the user to click the charts & perform operations, or drag things around, etc. I.e. if I want something dynamic, or if a static image will suffice
