We have an application where the customer has changed their mind about a large area of functionality and this area requires a large amount of re-work.
Whilst the re-work itself is not an issue, it has introduced a situation where the impact of the changes is wide ranging including:
  • Data
  • Query Logic / Table structure
  • Business logic
  • Display / Presentation
Ideally we'd like to incorporate these changes at the same time as several other development streams, but we're worried that the impact of the changes will have a negative impact on how frequently we can deliver. We can cater for some of this through branches, but it made me wonder what the possibilities are for guarding against this kind of thing from an application architecture or development practice point of view.
Things we currently do:
  • Abstract query logic into repositories - This is great for small changes, but when the overall logic in an area changes, e.g. instead of getting a list of users which meet a certain criteria, we now need to get a list of organisations which joined to locations.
  • Abstract business logic into services - This is exactly the same as the repositories in that we can't really guard against entire logic shifts, but small changes can be accommodated with limited impact.
  • Ensure configuration is kept out of code which needs re-deployment, a combination of database rows or web.config values.
  • Other patterns which promote aspects of flexibility like factories where appropriate etc.
  • Feature flagging for selection of functionality if two approaches were developed originally. etc
Are there any other current best practices to guard against changes, without incorporating branches etc?
dougajmcdonald
  • 315
  • possible duplicate of [What characteristics or features make code maintainable?](http://programmers.stackexchange.com/questions/134855/what-characteristics-or-features-make-code-maintainable) – gnat Jan 21 '15 at 14:15
  • Yeah I guess that could be true, I think I was thinking that the code itself 'is' (to an extent) maintainable, but are there any ways of managing two parallel versions of code, without impacting on the ability to deploy. One option would be to develop a second version alongside, e.g. via branches. Whereas another option may be to duplicate the code and feature flag one, until the second is complete. – dougajmcdonald Jan 21 '15 at 14:24
    @dougajmcdonald it's unclear to me what you're asking. Does the problem lie in the fact that other developers working on unrelated stuff are hampered by these breaking changes ? Or that it takes time to get big reworks right (which there's honestly not a lot you can do about...) ? – guillaume31 Jan 21 '15 at 14:58
  • I would argue to remove the C# tag. This type of thing is applicable to any language capable of building a large client application like this. – Neil Jan 22 '15 at 08:46
  • Some things that come to my mind, which, while they probably won't be relevant directly, might be handy to have in mind as you go along, are: [branching by abstraction](http://martinfowler.com/bliki/BranchByAbstraction.html) and [Hexagonal architectures](http://alistair.cockburn.us/Hexagonal+architecture) – paul Jan 22 '15 at 20:47
The only thing you can do to help reduce the impact of a change is to split your overall project up into many components, so while a major change will impact several of them, many will not be affected.
eg if the customer decides they need a new button that sends data through the middletier to be stored in a new column in the DB, you're going to have to change every layer in your system. However, if the system is also split 'horizontally' too then the UI impact will only affect part of the UI layer, the rest will not be changed. Similarly, if you have a lot of services in your middle tier that each process certain parts of the data, you'll only have to change one of them - the rest will be unaffected. the DB too, can be partitioned into independant schemas.
So for example, you need to get a list of users, so you have a service that manages user data. When you need to get a list of organisations too, you add a new service that deals with this and merge the data together in the UI (for example) which means you have not had to alter your user-access code at all. I think this kind of approach is termed microservices, though obviously 'micro' doesn't have to mean tiny, just logically separated.
I would not try to introduce abstractions as all that will happen is these will tie your layers together (eg a DB change will still require the underlying table change, but now the wrapping DAL layer will need change too, and having a DAL will not necessarily let you split the DB into sections, unless you get into a lot more complexity).
gbjbaanb
  • 48,354
  • 102
  • 172
  • Interesting answer, this sits with my current thinking in that there isn't an easy way to accommodate changes which impact vertically. Annoyingly, although I can divide the changes vertically into stories, the completion of one (or even a collection) of stories, doesn't leave the user in a working state. I'm wondering if the best approach at the moment is to split the changes into 'breaking' and 'non breaking' and incorporate the 'non breaking' into the main development stream, with 'breaking' as it's own arm. – dougajmcdonald Jan 21 '15 at 14:37
    Surely completion of a collection of stories (eg update UI, logic, DB) should leave it in a working state - what else is needed after all! In terms of stories, the story should be "add functionality" and that is them split into 3 tasks - update UI, update Logic, update DB. Never try to use 'breaking' and 'nonbreaking' as you never want a nonbreaking story that turns out to have breaking consequences. – gbjbaanb Jan 21 '15 at 14:39
    @dougajmcdonald as it is, there is no easy way to accommodate major changes except rolling up your sleeves and getting on with it :-) – gbjbaanb Jan 21 '15 at 14:42
  • Yeah I get what you mean, I think this is more than the collection of stories is the entire workpackage, which could take several months. The code, during this phase would be non-deployable but we have other work during this period on the same project which does need to be deployed. As a result, I'm looking for approaches which could allow parallel development and retain the ability to deploy, during a potentially unstable state for 'some' of the code. – dougajmcdonald Jan 21 '15 at 14:58
  • @dougajmcdonald: In what way would the system be non-deployable? In the sense that it doesn't work in the way the client wants, or in the sense that nothing works at all? – Bart van Ingen Schenau Jan 21 '15 at 15:34
  • In a way that the amount of change needed, is not possible to deliver in a single sprint, without breaking related areas of the system. An example would be, by changing the structure of the data storage, the existing data may not be able to be displayed properly or a report no longer works as the underlying data is depend on is too different. Making the report 'work' as part of this sprint may be pointless as during the next sprint, the next change may again change the way the report needs to operate. – dougajmcdonald Jan 21 '15 at 17:23
  • I can see one way of working, whereby we always make sure everything 'works' but this would quite often add a significant amount of effort to the task. Take a report, during sprint one, we 'make it work' with the changes in order to remain deployable. During sprint two we make it work again with some more changes, and again in sprint 4, 5...20. At this point we've re-written the report many times, when if we had been able to wait until the end, a single re-write would have been possible. – dougajmcdonald Jan 21 '15 at 17:26
  • @dougajmcdonald 2-weekly sprints are overrated, and if they get in the way of producing working code, then they are downright broken. Ditch the dogma, pick a longer "sprint" in your case and/or leave the UI to the next iteration after finishing the APIs. Remember Agile is not about blindly following any rule, make your own rules that work for you. – gbjbaanb Jan 21 '15 at 20:10
-1
Unit tests and Integration tests can be used to protect your logic from code changes.
  1. If you currently have a good code coverage, and you need to re-work a section, then the approach would be easier, you can change your tests to reflect the result after the re-work and once you have done the change you can re-run the test cases, to make sure it's all working. (In practice it would be a good idea to use a continuous integration server to run tests after each commit, and with this you can do smaller changes at a time and make sure all the logic is intact with the CI server status)
  2. If you do not have tests, then it would be a good idea to create some. If you are under tight deadline, you could start with integration tests where the tests will verify the output of the given input from the presentation level. For each place where change is needed you can start with creating tests for the expected output after the changes, and do the changes so and make sure tests are green.
Low Flying Pelican
  • 1,602
