I have an application where users will be able to upload multiple images for one Product (via something like Ryan Bates nested fields, so you'd click "Add Image", and a file upload would appear on the same page). I'm planning on using jQuery File Upload, and Amazon S3, and nested fields.
The thing I'm confused about, is how people usually associate many images with a single model.
For example, if for every Product, there can be many Images, how do I store the images to be associated with the Product?
I was thinking of having jQuery File Upload return the s3 url for each image. So if 10 images were uploaded, then 10 hidden fields were created for each image-url, which I then JSON serialize and store in the Product model?
But this doesn't seem like a pretty solution? What's a better method?
the_
  • 123
Your main question is,
So I'll focus on that:
In practice, Rails devs do this by using one of the gems for uploading and attaching images. E.g., Paperclip is maintained by Thoughtbot, is very well tested and supports S3.
But if you're more interested in experimenting and writing your own, you should take a look at Paperclip's source code to see what the current state-of-the-art is.
Dogweather
  • 513
It sounds to me like you 2 tables: a Product table, and an Image table. The Image table will have a foreign key back to the Product table and will store the image URL.
This way, a single Product can have a bunch of Images.
     Product                           Image
    |ProductID        |<------------+| ImageID   |
    |ProductName      |              | ProductID |
    |... and so on ...|              | ImageURL  |
(ImageID doesn't really matter much for this diagram)
Dan Pichelman
  • 13,773
  • 42
  • 73
  • but because I'm using nested fields, I don't yet have the Product Id when I save the image id via a jquery File Upload ajax request? – the_ Jan 29 '15 at 05:16
  • Three things you can do: (1) save the parent first to get the ID, (2) have an ID generator you can call to set the ID before you save it, or (3) generate a separate (non-primary) ID to act as a surrogate key and store that in a separate field in `Product` (say `ProductImageID`). – TMN Jan 29 '15 at 16:35
  • @TMN, how could I make sure the surrogate key is unique though? – the_ Jan 29 '15 at 20:33
  • @the_ You can consider creating a product record as soon as your users enters the page. This way you have an ID nice and early. You can have a process which cleans out the DB from not finished products. – Allan Spreys Jan 30 '15 at 09:12
  • @the_: Use something like a UUID or a database sequence (if your database software offers one). If your data volume is low enough, you could probably get away with something like (user ID + timestamp). – TMN Jan 30 '15 at 13:31
  • @TMN, would using something like `SecureRandom.hex` be enough? Or is UUID a better solution? I use Postgres – the_ Jan 30 '15 at 16:04
    @the_: UUIDs would be better, since random number generators can (by design) produce the same number more than once. Since you're using Postgres, I'd recommend just using a sequence. – TMN Feb 02 '15 at 16:54
