15
Context
I'm designing a database which, simplified, should be able to handle users sending job requests to each other, and after that a job can be started, finished, and reviewed. The design should be scalable (think millions of users).
Approaches I've considered:
Gargantuan table
One approach, probably not the best one, would be to simply store ALL jobs in one, huge table jobs. This table would need a state column to represent which state the job is currently in (e.g. ACCEPTED, STARTED, FINISHED, REVIEWED e.t.c.). The biggest problem with this approach that I can see is that jobs in different states have different types of data that are relevant to them. For example, a job request has a preliminary agreed upon price, but that could change before the job is started, and change again before the job is finished. This could of course be solved by just adding more columns to the table and naming them properly, but it will probably become a huge bottleneck performance-wise very early to have one table containing all the different types of possible data for all the different possible states of a job.
Different tables for different states
This approach would be to have multiple tables, for example job_requests, jobs_started, jobs_finished, tables who in turn can have substates, e.g. job_requests could have the sub-states PENDING, ACCEPTED, while the jobs_finished table would have the substates COMPLETED, CANCELLED, REVIEWED.
With this approach each table only contains data which is relevant to the current job state, but on the other hand some data might be duplicated (for example the user ids of the job requester, and job receiver -- on the other hand this information could be stored in yet another table?). The problem with this approach is that I can't think of a good solution on how to archive all the information when transitioning between states. For example, once a job request has been accepted, and then started, it should be deleted from the job_requests table and moved into the jobs_started table, but it's just a matter of time before a stakeholder wants to know for example how long the average time is between a job request being created, until it's been started, at which point I'd need the data from the job_requests table to be able to calculate it.
It feels like this type of problem should be easy to solve, but I really can't think of any good solution which "feels right", any solution I come up with feels ugly and I can immediately think of a number of things which makes the solution bad.
Very grateful for any feedback or tips on approaches I could take. Thanks in advance!
Atra Azami
  • 253
    It appears like you are using a relational database. Is it an option to use a noSQL database? 'records' in those databases don't have a static schema, so you can modify the data (and state of course) in these 'records' easily. You've probably thought of this already, but I couldn't find it in your post. – Jan_V Jan 07 '15 at 20:52
  • Yes it's definitely an option. If you think it would be a better idea to use a noSQL database, could you please elaborate in an answer? I'm not sure what the best approach would be to solve this problem with noSQL, and what the pros/cons of using it in this case (vs. a relationaldb solution) – Atra Azami Jan 07 '15 at 21:02
  • You are creating a http://en.wikipedia.org/wiki/Finite-state_machine. Normally, I would do that in the app itself. If you _must_ have a database then I highly recommend Different tables for different states. – Mawg says reinstate Monica Jan 08 '15 at 09:48
Sounds like you have 3 major categories of data you are trying to store:
  1. General job data (job id, job requester id, job receiver id etc)
  2. State transitions (job started, job finished)
  3. State-specific job data
  4. (optional) job-related events (price changed, job receiver user reassigned etc)
The key is to separate event-like data from everything else.
Schema design
Here are some details:
1. General jobs table
All of the information that's NOT state-specific goes into the (let's say) "jobs" table. Auto-generated primary key: job_id
2. State transitions table
All information about state transitions goes into "job_state_transitions" table, which might have the following columns:
  • job_transition_id
  • job_id
  • created_at
  • from_state
  • to_state
Ideally this table is append-only. Nothing is every updated or removed here.
Using such a table, you can find out the latest status of any particular job by selecting the latest row for a given job_id from the job_transitions table. You can further denormalize that and introduce a "job_state" column, the contents of which are updated every time a new row is inserted in job_transition table (stored procedures might help here if that's your thing).
You can also do all sorts of analysis on state transitions, because the timing data is preserved (created_at is a date/time field that can help with that)
All of the state-specific data goes into "[state]-jobs" tables. Primary key: some sequence id. Main index: job_transition_id
4. Optional event data
You can also introduce an "audit trail" table that allows you to keep track of various changes that users might request for each job, like your "change agreed upon price". This is a generalization of the state transition table: one main table that contains events and a one supplemental table for each event type (for example, price_changes table with job_id, created_at, from_price and to_price columns).
Scaling to millions of users
If the main "jobs" table grows to be unwieldy, you can shard it by job_id or requesting_user_id or something like that.
Likewise, events table should be append-only and can be rotated or purged of events related to jobs that have been finished.
pbkhrv
  • 516
    This is the way it's supposed to be done. What's in common stays in one table, with foreign keys from other tables referencing it. Immutable state tables allow you to track every single change (although you don't really need a `from_state`, since that's implied by the last value). Instead of denormalizing it, use a view. – mgw854 Jan 08 '15 at 02:43
    Ah, can't believe I didn't think of having a state transitions table! Lots of useful input here - thank you very much. – Atra Azami Jan 08 '15 at 10:14
  • @mgw854 great point about using views if the database tech supports it – pbkhrv Jan 08 '15 at 16:20
  • As a Database guy I would also say have the latest job state stored with the main Job Data Table (JobStateID foreign keyed to a description table). Yes that means you will update that table on state change but it makes finding the current status of all jobs very easy. I then also use a history table to track the Job State transitions. – RubberChickenLeader Jan 09 '15 at 15:02
  • @WindRaven Couldn't I achieve the same thing by just joining the state transition table to the jobs table, ordering it by latest creation date limit 1, when querying for jobs? That would eliminate the redundancy of also storing it in the main job data table, if I understand your suggestion. Having job_id be indexed on the state transition table would also bar any performance impacts. – Atra Azami Jan 10 '15 at 11:49
  • @AtraAzami You could however querying the table for all running jobs is quite a bit easier if you denormalize and keep the most recent state in the Jobs table. Also depending on your RDBMS you could create a filtered index and have even faster searches for current status – RubberChickenLeader Jan 12 '15 at 14:53
How about a hybrid of the two? A large table with a JobID and state (and perhaps other information common to all jobs and states), with other tables to manage the additional state information. That reduces (or eliminates) the duplication of data, but keeps things more manageable.
Jim Nutt
  • 497
You might want to consider using a noSQL database for this specific data. This way you can just put your object in a record, no matter what the 'columns' are.
Depending on the chosen database system (and implemented solution), you would be able to 'overwrite' a record with different data if you want. Of course, you can also save your historic data and just PUT a new record in the database.
You can start out with this record:
myStartedObject{
    state:  'started',
    agreedUponPrice:    100.00,
    someOtherData:  'x'
and over time it would change to something like this, or if you want to keep the history records, the id would change.:
myFinishedObject{
    state:  'finished',
    finishedPrice:  209.00,
    someFinishedData:   'y'
Storing all state date inside the object is also an option of course, something like this:
myObject
    states: [{ state: 'started', agreedUponPrice: 100.00, someOtherData: 'x'},
        { state: 'finished', finishedPrice: 209.00, someFinishedData: 'y'}]
Keep in mind, this surely isn't the silver bullet, but it might be something to consider as you state your 'schema' is quite loose and you don't want to pollute your RDBMS with all of those columns.
Also keep in mind, any RDBMS can do this also. I know in MS SQL you have the XML data type. With this, you can store your data in this XML column. This XML column can contain your deserialized object for instance. It's not a 'real' noSQL solution, but it looks a bit like one.
Jan_V
  • 1,622
If you treat this problem as a workflow problem, you can employ one of the workflow tools such as jBPM or Windows Workflow Foundation and focus on the business logic and let the tool handle the persistence for you.
sevzas
  • 99
