I've searched around for a long time now and haven't come up with any official reason why scala doesn't support multiple inheritance. I know traits solve a lot of things, but the developers of C# for example give an explicit reason why not to implement it (link here).
Any pointers?
Glorfindel
  • 3,137
voluminat0
  • 321
Scala does support Multiple Inheritance: you can inherit from as many traits as you want.
So, the reason for why there is no official documentation for the reasons for not supporting MI is simply that there aren't any, because Scala does support MI. You say "traits solve a lot of things", and MI is one of them.
Jörg W Mittag
  • 101,921
  • 218
  • 318
    Yes, any class or trait may inherit from multiple traits. But for some reason, you can't inherit from more than one class. Why and how are traits and classes different? Why this restriction on class inheritance? I do not believe this post answers the question. – amon Jan 03 '15 at 09:29
  • per my reading of the question, asker appears to be already aware of that: "I know traits solve a lot of things" (in the light of this, concern raised by @amon seems to make much sense) – gnat Jan 03 '15 at 10:40
    @gnat: the OP says "I know traits solve a lot of things", but he doesn't elaborate on what those "lot os things" and what is missing from those "lot of things". His main point seems to be that there is no official documentation for the absence of MI, and the reason why there is no official documentation for the absence of MI is that there is no absence of MI. – Jörg W Mittag Jan 03 '15 at 12:54
One of Scala's primary design goals is to interoperate with Java as smoothly as possible. In order to achieve this, a Scala class must have a one-to-one correspondence with a JVM class. Because the JVM ddoesn't support multiple inheritance, it would therefore be impossible for Scala to do so without introducing massive hacks.
Jules
  • 17,614
  • 63
    Source for your statement ”the JVM doesn't support multiple inheritance”: [the JVM Spec, section 4.1 “The `ClassFile` Structure”](http://docs.oracle.com/javase/specs/jvms/se8/html/jvms-4.html#jvms-4.1) states that class descriptions contain a *single* `super_class` field that can either be empty or reference a superclass, whereas classes can reference any number of interfaces. – amon Jan 03 '15 at 12:20
