To keep my question short and to the point, consider this:
$relation = $mysql->query("SELECT relation($loggeduser, $requesteduser) AS a")->fetch_assoc()['a'];
if ($relation != BLOCKED)
return $mysql->query("SELECT stuff FROM sometable WHERE powerlevel>9000 LIMIT 39");
} else {
return '{"error":"not enough jquery"}';
Where relation
is some MySQL function. When would this^ approach be better than something like this:
$stuff = $mysql->query("SELECT getstuff($loggeduser, $requesteduser) AS a")->fetch_assoc()['a'];
return ($stuff != null) ? $stuff : '{"error":"stop it"}';
Where getstuff
is some MySQL function that just does everything that the first code would do.
In this scenario, the second seems to make a lot more sense. In reality, the second makes sense for so many other scenarios I can think of to the point where you can have a web app essentially composed of just MySQL functions that deal with almost everything you need (i.e. getUsers, getFollowers, pageInfo, etc.).
However, I'm surely missing something, and my question is this - When should I not use MySQL functions over server-sided scripting operations? You can omit the obvious (i.e. saving/processing files, etc.).
