It seems that writing Declarative SQL
is very popular in Imperative Programming. However, it also seems that writing Declarative Prolog
could save a lot of complexity but this is not very common.
Is there a historical precedent for this apparent preference of SQL over Prolog?
If the reason is lack of native support by Imperative languages, then is it possible to answer why the language creators didn't find it useful to natively support Prolog
in the first place?
To provide some specific examples:
Example 1
Evaluating a loan application might be just a few lines of code in Prolog
, like the SELECT/JOIN
query that is just a few lines of code in SQL
, but it seems the advantage is not as obvious as SQL
Example 2
Here is another example problem and the solution in Prolog. The following constraint logic program represents a simplified dataset of john's history as a teacher:
teaches(john, hardware, T) :- 1990 ≤ T, T < 1999.
teaches(john, software, T) :- 1999 ≤ T, T < 2005.
teaches(john, logic, T) :- 2005 ≤ T, T ≤ 2012.
rank(john, instructor, T) :- 1990 ≤ T, T < 2010.
rank(john, professor, T) :- 2010 ≤ T, T < 2014.
The following goal clause queries the dataset to find out when john both taught logic and was a professor:
:- teaches(john, logic, T), rank(john, professor, T).
Result:
2010 ≤ T, T ≤ 2012.
In the above example it will be easy with SQL
to get the same result. But suppose that you have this data in an Array
. Then it is not as easy to get the same results using SQL
. And in the case of data stored in an array, I believe that the Prolog code will be easier to write and maintain.
