16
Alan Kay said "OO" was about messaging, not objects and drew a parallel to biological cells.
His views are enticing, but vague. The way I understand it is something like a Cellular Automata.
In a Cellular Automata there's a grid of cells that can be in a variety of states. Then an update event is sent to all the cells. In response, the cells update their state based on their own state and the state of their neighbors.
So if we assume...
Grid => Software System
Cell => Object
Update Rule => Event/Message
Then we have a starting point. Locality differs (unless we define neighbors as objects that are connected), and there isn't one update rule, but a variety of messages/events that objects can respond to.
Having used cellular automata, I'm aware of their power and the awesome global emergence that arises from local interactions. Thinking of this applied to the sphere of objects is breath-taking.
Or perhaps to put it another way, it's an extreme event driven system in which a network of objects forms the architecture, (global?) events define the information flow, and the interaction of these objects defines the system behavior.
Is this understanding correct? If not, I'd love clarification and even examples of code written in this message system (vs. code that's not), to make this concrete.
R. Barzell
  • 289
    It doesn't have to be cellular automata. Cellular automata is just one very specific example, and message passing isn't even required for cellular automata to work. Message passing is very useful in a wide array of applications, regardless. – Robert Harvey Dec 05 '14 at 20:33
  • @gnat: There is indeed some resemblance there, but I'm not sure the question is a dupe. This one seems to focus more on message passing specifically. – Robert Harvey Dec 05 '14 at 20:44
  • @RobertHarvey question seems to be [somewhat vague](http://meta.programmers.stackexchange.com/questions/6483/why-was-my-question-closed-or-down-voted/6489#6489) but per my reading, the dupe I suggested fits better than, say, other similar question - [what is message passing in OO?](http://programmers.stackexchange.com/questions/140602/what-is-message-passing-in-oo) – gnat Dec 05 '14 at 20:47
    @gnat: You're probably looking at the [*answer*](http://programmers.stackexchange.com/a/58732/1204) (which answers this question pretty well also). – Robert Harvey Dec 05 '14 at 20:49
  • See also [The Deep Insights of Alan Kay](http://mythz.servicestack.net/blog/2013/02/27/the-deep-insights-of-alan-kay/) – Robert Harvey Dec 05 '14 at 20:50
  • @RobertHarvey correct, once I've read that answer, I dropped the idea to dupe to that other question – gnat Dec 05 '14 at 20:51
  • @RobertHarvey I read the referenced posts, and at least 2 correspondences with Alan Kay before posting my question. Definitely not a dupe, but maybe I can be more precise in my question and perhaps reference the other questions and why they didn't answer my question. – R. Barzell Dec 08 '14 at 13:14
  • @R.Barzell: That's a good idea. If you read the answer at the duplicate and the blog article I linked, you would already know that messaging (while undoubtedly very important to Kay) was only one part of his larger thought process. – Robert Harvey Dec 08 '14 at 16:16
  • See also http://programmers.stackexchange.com/a/81261. I suspect this has mostly to do with side effects. – Robert Harvey Dec 08 '14 at 16:24
  • @RobertHarvey thanks. The answer sounds like the normative practice of ensuring classes maintain their invariants. – R. Barzell Dec 08 '14 at 21:51
  • Maybe Alan Kay meant Smalltalk(Pharo) and Excel... – aoeu256 Aug 28 '19 at 19:09
The key to Alan Kay's view is the reason why a message is sent.
When an object of class A sends a message to an object of class B because A wants B to do something specific, that isn't OO (according to Kay's vision.) If A is sending the message to inform B that something has happened (rather than telling it to do something,) that is OO.
A good example of this is an onClick method that informs something that a button was clicked.
A bad example would be the append method on a container. This isn't OO programming, rather it is bog standard modular programming. There's nothing wrong with modular programming mind you, but it is different than OO.
EDIT
I feel the need to defend the above somewhat... Refer to Alan Kay's email that was posted in the question (here). Notice quotes like, "I wanted to get rid of data." Notice how he keeps coming back to the notion of avoiding data in favor of sending messages to objects.
When you tell a container to append, you are explicitly dealing with data. You care whether or not the container's size attribute increased. Whenever a function is called because the caller wants to ensure the called's post-condition, that is a reference to data, either explicit or implicit.
Mr. Kay wanted to avoid that, and this means that OO is about sending messages to inform objects of things happening, not to force them to change their state.
Daniel T.
  • 3,013
  • Yesterday read a post hon how to model O.O. Messaging in an application, is just not directly supported. – umlcat Dec 05 '14 at 22:24
    You're basically describing the Subscriber pattern as it relates to UI, the bane of every Winforms and VB programmer that ever existed (read: Big Ball of Mud). It's essentially the motivation for patterns like MVC and MVVM: to lower coupling and improve cohesion. I don't think this is what Alan Kay meant at all. – Robert Harvey Dec 05 '14 at 22:30
    @RobertHarvey I think `b.inform(event)` totally fulfills what Daniel said, and it does not use the pub/sub pattern. You can try to make something usable with pub/sub only, I already experimented with such systems, but they are problematic, because you lose abstraction layers if everything is loosely coupled and there aren't clear dependencies between the objects. I am not sure though that this event only approach works. It is hard to name the methods with it, but I'll try it out. – inf3rno Sep 21 '17 at 22:44
  • This might be related to https://martinfowler.com/bliki/TellDontAsk.html but I am not sure. Can you write some examples Daniel? – inf3rno Sep 22 '17 at 10:03
  • I checked, "tell don't ask" is about encapsulation or in other words not exposing data. It has probably nothing to do with message passing. Btw. I am not sure what he meant, because message is an overused word and he did not give us the definition in his context. So I think this will remain a mystery... – inf3rno Sep 22 '17 at 12:55
  • I am not sure event-driven was @AlanKay's conception of message-passing, as you describe it. The source you gave does not corroborate that, at least. He laments the use of RPC, that is true. But I think what he derided with RPC was the use of it to directly access the interiors of objects (instead of objects providing abstracted APIs / setters that handle all the internal relationships), as he expounds upon here: https://softwareengineering.stackexchange.com/a/81261/104312 – Magne Jan 24 '22 at 17:44
  • In fact, in Smalltalk (Alan Kay's language, that implemented his ideas of OO), messages specify a distinct _receiver_ address. Events in event-driven systems generally do _not_ specify a receiver, but simply inform of something that happened at the sender. So messages don't simply _inform_ in the way events do. Sources: http://propella.sakura.ne.jp/earlyHistoryST/EarlyHistoryST.html and https://en.wikipedia.org/wiki/Smalltalk#Messages – Magne Jan 24 '22 at 18:45
