I'm having a problem with the design of my application, that neither optimistic nor pessimistic locking tends to solve. Here is a simplified/altered version of the problem that describes the situation.
Premise of the problem:
  • A document-processing application
  • A database where documents are stored
  • Multiple clients simultaneously access the database
What I try to achieve:
Say there are 10 unprocessed documents in the database. The first client requests the number of unprocessed documents. The response is 10. He requests 6 of them and starts processing. Before he finishes the second client requests the number of unprocessed documents. There is no point for him to process the same documents as the first client, so I want the program to answer "There are 4 unprocessed documents".
The problem if I optimistically lock those 6 documents:
In the particular case of this application transaction will take a long time and there is a big chance that other client still thinks that there are 10 unprocessed documents, not 4.
The problem if I pessimistically lock those 6 documents:
Again, the transaction takes a long time to complete and the other client will get stuck waiting for an answer about the number of documents.
The problem if I shorten the transaction and commit a status change before processing:
There is a chance that a power outage occurs, as a result 6 documents have a status "exported for processing", but in reality they aren't.
What alternative/custom locking strategy should be selected for this kind of scenario with concurrent access and long transactions?
Limbo Exile
  • 705
  • don't allow a client to have more than 1 document locked at a time? – ratchet freak Nov 26 '14 at 13:42
  • Maybe I oversimplified my example. In fact, there are two separate applications. One for the export of documents, another for the actual processing. These 2 apps must not be on the same machine. Hence possibility to export multiple documents is obligatory. – Limbo Exile Nov 26 '14 at 13:48
  • Does already the export need a long time, or only the processing afterwards? – Doc Brown Nov 26 '14 at 14:01
  • When a client chooses to export 100 documents (which is very possible) the export alone can take up to 5 minutes, maybe more. – Limbo Exile Nov 26 '14 at 14:03
  • In addition to the strategy outlined in the [answer by Doc Brown](http://programmers.stackexchange.com/a/263835/5099), keep a record of which user started processing a document and allow a user to retrieve which documents they are supposed to be processing. – Bart van Ingen Schenau Nov 26 '14 at 14:33
I would try to solve this with (at least) four document states
  • unprocessed
  • export started (but not under processing)
  • under processing (means: after export finished)
  • processed
Moreover, it will be probably a good idea to add a timestamp field to remember when the last state was changed, and as @Bart pointed out, an additional field which user caused the state change.
The state changes itself should be done for each document individual, in a single, short, atomic transaction. For example, before the export starts, set the state acccordingly. After the export was successfully finished, you set the state accordingly, too. When the document was processed, again. This gives you fine-grained control over the transactions and will allow individual failure-recovery.
For example, assumed there is a power outage, or a network outage in the middle of an export of 100 documents, this will leave you with about 50 docs in state "export started" and 50 docs "under processing". Using the timestamp field, you can now easily detect when there are documents for which the state is still "export started" for more than, lets say, 15 minutes, and reset those docs back to "unprocessed" after this time out. You can also reset docs from "under processing" back to unprocessed when the processing takes more than, lets say, 5 days. The check for these pending state may be done in a separate background program, running, for example, every minute, or every five minutes, whatever suits your process best.
Actually, "locking of those documents" should mean: all docs with the state different from "unprocessed" are locked for export & processing from others - but not by using a long lasting "database lock mechanism". The database should always stay responsive and tell you how many documents of which state are stored. To my understanding, this is still called a "pessimistic lock" strategy (since the same document is not to be processed by two different users at the same time), but with a failover strategy.
Doc Brown
  • 199,015
  • 367
  • 565
  • This will do nicely. Now I can see the shortcomings of my model: transactions aren't atomic and the absence of "export started" state. Thanks! – Limbo Exile Nov 26 '14 at 14:51
There are more gradations in "locking" than just pure pessimistic ("don't allow any other accesses of this document while it's being looked at!") and pure optimistic ("assume that no accesses of or updates to this document will ever conflict with one another!").
  1. There's more granular, still-pessimistic locking. E.g., allow clients to only take out one document at a time. This is akin to "row level locking" rather than "table locking" in DBMS design.
  2. Multi-version concurrency control is what most modern database managers use instead of truly pessimistic locking assumptions. It can provide the same ACID properties as traditional pessimistic locking.
  3. Concurrent real-time editors like Google Docs and EtherPad allow multiple concurrent updates from multiple clients to a consistent document model. Both the upside and the downside is that there is no "checkout" feature, and logical/semantic coordination is the responsibility f the clients.
  4. Distributed revision control systems like Git and Mercurial take a very optimistic, permissive view: Everyone gets copies of all the document they want, and can make whatever changes they want. When they later want to commit those changes back, the assumption is that all changes can be successfully merged/re-integrated into the master (and if that can't be done with complete automation, that any hard conflicts can be automatically identified and presented to a human for sorting out).
But rather than a locking strategy, it sounds like you might need a distributed job scheduler. Every HPC environment from time immemorial to today has some form of job scheduling, including error handling for when jobs die or go AWOL. So in addition to alternate strategies for managing document locks yourself, consider whether this functionality could be more easily outsourced to a job manager.
Jonathan Eunice
  • 9,710
  • 42
