(sorry, my first time through I missed the /edit/ and /delete/ in (2)... )
The idea of the URI is that it is an identifier of an addressable resource, rather than a method invocation. So the URI should point to a specific resource. And if you deference the URI, you should always get the same resource.
That is, you should think about URIs in the same way you think about the Primary Key of a row in a database. It uniquely identifies something: Universal Resource Identifier.
So whether you use plural or singular, the URI should be an identifier rather than an invocation. What you're trying to do goes in the method, namely: GET (get), PUT (create/update), DELETE (delete) or POST (everything else).
So "/item/delete/123" breaks REST because it doesn't point to a resource, it's more of a method invocation.
(Also, just semantically, you should be able to GET a URI, decide it's outdated, and then DELETE the same URI -- because it is an identifier. If the GET URI doesn't have "/delete/" and DELETE does, then that goes against HTTP semantics. You're broadcasting 2 or more URIs per resource where 1 will do.)
Now, the cheat is this: there's no real clear definition of what is and isn't a resource, so the common dodge in REST is to define a "processing noun" and point the URI to that. That's pretty much a word game, but it satisfies the semantics.
So if, for example, you really couldn't use this for some reason:
DELETE /items/123
you could declare to the world you have a "deletor" processing resource and use
POST /items/deletor { id: 123 }
Now, that looks a lot like RPC (Remote Procedure Call), but it falls through the vast loophole of the POST specification's "data processing" clause named in the HTTP spec.
However, doing that is kind of exceptional, and if you can use the common PUT for create / update, DELETE for delete, and POST for append, create, and everything else, then you should, because it's a more standard use of HTTP. But if you have a tricky case like "commit" or "publish" or "redact", then the case for using a processor noun satisfies the REST purists and still gives you the semantics you need.
