70
Suppose I have a function that does things with a text file - for example reads from it and removes the word 'a'. I could either pass it a filename and handle the opening/closing in the function, or I could pass it the opened file and expect that whoever calls it would deal with closing it.
The first way seems like a better way to guarantee no files are left open, but prevents me from using things like StringIO objects
The second way could be a little dangerous - no way of knowing if the file will be closed or not, but I would be able to use file-like objects
def ver_1(filename):
    with open(filename, 'r') as f:
        return do_stuff(f)
def ver_2(open_file):
    return do_stuff(open_file)
print ver_1('my_file.txt')
with open('my_file.txt', 'r') as f:
    print ver_2(f)
Is one of these generally preferred? Is it generally expected that a function will behave in one of these two ways? Or should it just be well documented such that the programmer can use the function as appropriate?
Dan Oberlam
  • 1,271
6 Answers6
45
Convenient interfaces are nice, and sometimes the way to go. However, most of the time good composability is more important than convenience, as a composable abstraction allows us to to implement other functionality (incl. convenience wrappers) on top of it.
The most general way for your function to use files is to take an open file handle as parameter, as this allows it to also use file handles that are not part of the filesystem (e.g. pipes, sockets, …):
def your_function(open_file):
If spelling out with open(filename, 'r') as f: result = your_function(f) is too much to ask of your users, you could choose one of the following solutions:
  • your_function takes an open file or a file name as parameter. If it is a filename, the file is opened and closed, and exceptions propagated. There is a bit of an issue with ambiguity here which could be worked around using named arguments.
  • Offer a simple wrapper that takes care of opening the file, e.g.
    def your_function_filename(file):
        with open(file, 'r') as f:
            return your_function(f)
    I generally perceive such functions as API bloat, but if they provide commonly used functionality, the gained convenience is a sufficiently strong argument.
  • Wrap the with open functionality in another composable function:
    def with_file(filename, callback):
            return callback(f)
    used as with_file(name, your_function) or in more complicated cases with_file(name, lambda f: some_function(1, 2, f, named=4))
amon
  • 132,749
  • 279
  • 375
    The only drawback of this approach is that sometimes the name of the file-like object is needed, e.g. for error reporting: end users prefer to see "Error in foo.cfg(12)" rather than "Error in (12)". An optional "stream_name" argument to ``your_function`` can be used in this regard. –  Nov 11 '14 at 08:48
26
The real question is one of completeness. Is your file processing function the complete processing of the file, or is it just one piece in a chain of processing steps? If it is complete in and of its own, then feel free to encapsulate all file access within a function.
def ver(filepath):
    with open(filepath, "r") as f:
        # do processing steps on f
        return result
This has the very nice property of finalizing the resource (closing the file) at the end of the with statement.
If however there is possibly a need for processing an already-open file, then the distinction of your ver_1 and ver_2 makes more sense. For example:
def _ver_file(f):
    return result
def ver(fileobj):
    if isinstance(fileobj, str):
        with open(fileobj, 'r') as f:
            return _ver_file(f)
    else:
        return _ver_file(fileobj)
This kind of explicit type testing is often frowned upon, especially in languages like Java, Julia, and Go where type- or interface-based dispatching is directly supported. In Python, however, there is no language support for type-based dispatching. You may occasionally see criticism of direct type-testing in Python, but in practice it's both extremely common and quite effective. It enables a function to have a high degree of generality, handling whatever datatypes are likely to come its way, aka "duck typing." Note the leading underscore on _ver_file; that is a conventional way of designating a "private" function (or method). While it can technically be called directly, it suggests that function is not intended for direct external consumption.
2019 update: Given recent updates in Python 3, for example that paths are now potentially stored as pathlib.Path objects not just str or bytes (3.4+), and that type hinting has gone from esoteric to mainstream (circa 3.6+, though still actively evolving), here's updated code that takes these advances into account:
from pathlib import Path
from typing import IO, Any, AnyStr, Union
Pathish = Union[AnyStr, Path]  # in lieu of yet-unimplemented PEP 519
FileSpec = Union[IO, Pathish]
def _ver_file(f: IO) -> Any:
    "Process file f"
    return result
def ver(fileobj: FileSpec) -> Any:
    "Process file (or file path) f"
    if isinstance(fileobj, (str, bytes, Path)):
            return _ver_file(f)
    else:
Jonathan Eunice
  • 9,710
  • 42
    Duck typing would test based on what you can do with the object, rather than what its type is. For example, trying to call `read` on something that might be file-like, or calling `open(fileobj, 'r')` and catching the `TypeError` if `fileobj` isn't a string. – user2357112 Nov 11 '14 at 00:01
  • You're arguing for duck typing in *use*. The example provides duck typing in *effect*--that is, users get the `ver` operation independent of type. It might also be possible to implement `ver` through duck typing, as you say. But generating then catching exceptions is slower than simple type inspection, and IMO does not yield any particular benefit (clarity, generality, etc.) In my experience, duck typing is awesome "in the large," but neutral to counterproductive "in the small." – Jonathan Eunice Nov 11 '14 at 01:05
    No, what you're doing still isn't duck typing. A `hasattr(fileobj, 'read')` test would be duck typing; an `isinstance(fileobj, str)` test is not. Here's an example of the difference: the `isinstance` test fails with unicode filenames, since `u'adsf.txt'` isn't a `str`. You've tested for a too specific type. A duck typing test, whether based on calling `open` or some hypothetical `does_this_object_represent_a_filename` function, wouldn't have that problem. – user2357112 Nov 11 '14 at 02:06
    If the code were production code rather than an explanatory example, I also wouldn't have that problem, because I wouldn't use `is_instance(x, str)` but rather something like `is_instance(x, string_types)`, with `string_types` properly set for proper operation across PY2 and PY3. Given something that quacks like a string, `ver` would react properly; given something that quacks like a file, the same. To a *user* of `ver`, there would be no difference--except that the type inspection implementation would run faster. Duck purists: feel free to disagree. – Jonathan Eunice Nov 11 '14 at 02:23
If you pass the file name around instead of the file handle then there is no guarantee that the second file is the same file as the first one when it is opened; this can lead to correctness bugs and security holes.
user541686
  • 8,074
  • 38
  • 49
    True. But that must be counterbalanced with another tradeoff: If you pass around a file handle, all readers must coordinate their accesses to the file, because each is likely to move the "current file position." – Jonathan Eunice Nov 11 '14 at 16:00
  • @JonathanEunice: Coordinate in what sense? All they need to do is set the file position to be wherever they want it to be. – user541686 Nov 11 '14 at 19:32
    If there are multiple entities reading the file, there may be dependencies. One may need to start where another one left off (or in a place defined by data read by a preceding read). Also, readers may be running in different threads, opening up other coordination cans of worms. Passed-around file objects become exposed global state, with all the issues (as well as benefits) that entails. – Jonathan Eunice Nov 11 '14 at 19:37
  • @JonathanEunice: I don't get it, how does passing around the file names instead of the handles solve this issue in any way? Either way all the readers have to know what part of the file you're reading from. – user541686 Nov 11 '14 at 19:40
    It's not passing around the file path that's the key. It's having one function (or class, method, or other locus of control) assume responsibility for "the complete processing of the file." If file accesses are encapsulated *somewhere*, then you do not need to pass around mutable global state like open file handles. – Jonathan Eunice Nov 11 '14 at 19:45
  • @JonathanEunice: Uh, that's not "counterbalancing with a tradeoff"... when you said that, it implied you were claiming there was some advantage to passing around the file names. But that's not what you're saying, so I don't have anything to say on the topic since it's not relevant to the comparison I was making in my answer. – user541686 Nov 11 '14 at 19:49
    Well, we can agree to disagree then. I am saying there is a decided downside to designs that glibly pass around mutable global state. There are some advantages, too. Thus, a "tradeoff." Designs that pass file paths often do I/O in one fell swoop, in an encapsulated way. I see that as an advantageous coupling. YMMV. – Jonathan Eunice Nov 11 '14 at 20:14
  • @JonathanEunice: Not sure what you're disagreeing about since we're talking about different things but ok. – user541686 Nov 11 '14 at 20:15
This is about ownership and the responsibility to close the file. You can pass on a stream or file handle or whatever thingy that should be closed/disposed at some point to another method, as long as you make sure it is clear who owns it and certain it will be closed by the owner when you are done. This typically involves a try-finally construct or the disposable pattern.
Martin Maat
  • 18,218
  • 30
  • 57
One aspect the other answers haven't pointed out is a "capabilities" approach. This is usually applied in the context of security, but can also help with design and development (e.g. defensive coding, debugging, testability, etc.).
Roughly: a "capability" is the information required to perform some action. If we have a capability, we can perform its corresponding actions; we can't perform actions without a corresponding capability. Examples of capabilities include URLs, API keys, username/password pairs, etc. Capabilities are useful since they focus on what could happen rather than what should happen.
In your case it seems like filenames and handles are roughly equivalent: they let us read files. Yet things aren't that simple, and capabilities give us a way to think about the differences.
Our code should read data from a file, so it needs the capability (AKA information required) to do so. Does a filename give us this capability? Not quite. In particular:
  • There might be no file with the given filename. In this case we can't read a file, so (according to my rough definition above) such filenames are not the capabilities we need.
  • If there is a file with the given filename, our program's user account might not have permission to read it. Again, from my rough definition, such filenames are not the capabilities we need: we would need some extra information to access them, like the login details of a permitted user.
Opened files (AKA handles or 'file-like objects') don't have these problems: permission or file-not-found errors will be thrown before our function gets called; and presumably (via the single-responsibility principle) the code that's trying to open those files is better placed to handle those errors or pass them on.
So filenames aren't always the capabilities we need. They might also give us extra capabilities we don't want, too! For example, given a filename we can (try to) delete it, rename it, move it, etc.; whilst we can't do that using a handle (at least, not as easily). If we write our code using a more restricted set of capabilities, it's less likely that we'll trigger some unwanted action by mistake; so this is another reason to accept handles instead of filenames. I would also argue that it makes understanding and debugging easier, since we can guess from its signature whether a function might be the source of a problem (like, say, files getting accidentally deleted). This way of thinking can also influence our design and architecture, since an important aspect is making sure each component has everything it needs to do its job (i.e. the right capabilities are available), whilst encapasulating/modularising/protecting other parts of the system from interference (i.e. restricting those capabilities).
Caveat: If we're relying on a capability model for security, it's important that capabilities are kept secret; are unguessable (e.g. we shouldn't be able to increment one valid ID to get another); and undiscoverable (e.g. the ability to list filenames should be restricted). We must assume that if something is plausible, then malicious actors will exploit it (e.g. digging deep into the attributes of a file handle to figure out the filename). If we're not concerned about malicious actors, I tend to assume that developers (including me) are mostly lazy: if there's an lazy solution and a tricky solution (e.g. reading from a given handle vs. figuring out its filename and opening it), then we can usually ignore the tricky approach when we're designing, since it's unlikely to be (ab)used.
Warbo
  • 1,205
If you choose to pass open files you can do something like the following BUT you have no access to the filename in the function that writes into the file.
I would do this if I wanted to have a class that was 100% responsible for file/stream operations and other classes or function that would would be naive and not expected to open or close said files/streams.
Remember that context managers work like having a finally clause. So if an exception is thrown in the writer function the file is going to be closed no matter what.
import contextlib
class FileOpener:
    def __init__(self, path_to_file):
        self.path_to_file = path_to_file
    @contextlib.contextmanager
    def open_write(self):
        # Here you can add code to create the directory that will accept the file.
        # And you can add code that will check that the file does not exist
        # already and maybe raise FileExistsError
        try:
            with open(self.path_to_file, "w") as file:
                print(f"open_write: has opened the file with id:{id(file)}")
                yield file
        except IOError:
            raise
        finally:
            # The try/catch/finally is not mandatory (except if you want to manage Exceptions in an other way, as file objects have predefined cleanup actions
            # and when used with a 'with' ie. a context manager (not the decorator in this example)
            # are closed even if an error occurs. Finally here is just used to demonstrate that the
            # file was really closed.
            print(f"open_write: has closed the file with id:{id(file)} - {file.closed}")
def writer(file_open, data, raise_exc):
    with file_open() as file:
        print("writer: started writing data.")
        file.write(data)
        if raise_exc:
            raise IOError("I am a broken data cable in your server!")
        print("writer: wrote data.")
    print("writer: finished.")
if __name__ == "__main__":
    fo = FileOpener('./my_test_file.txt')
    data = "Hello!"
    raise_exc = False  # change me to True and see that the file is closed even if an Exception is raised.
    writer(fo.open_write, data, raise_exc)
Vls
  • How is this any better/different than just using `with open`? How does this address the question of using filenames vs file-like objects? – Dan Oberlam Oct 15 '19 at 12:52
  • This shows you a way to hide the file/stream open/close behavior. As you can clearly see in the comments it gives you the way to add logic before opening the stream/file that is transparent to the "writer". The "writer" could be a method of a class of another package. In essence it is a wrapper of open. Also, thank you for replying and voting. – Vls Oct 15 '19 at 14:09
  • That behavior is already handled by `with open` though, right? And what you're effectively advocating for is a function that only uses file-like objects, and doesn't care where it came from? – Dan Oberlam Oct 16 '19 at 20:10
