I am trying to write a script that will take multiple paths to files on various servers, search them all simultaneously, and return a single list of results to a user. Initially, I was just using Python threads to do this, however I quickly ran into some noted problems:
  1. I wasn't controlling how many threads could be kicked off. So if someone sent 100 files to query for one server, you'd have 100 threads kicked off on that machine, which was bad news.
  2. The results I was getting back were incomplete and varied drastically. If I ran the searches linearly (no threads), I would get complete results, but it would take a long time. I concluded based on this and some personal research that I was not taking a thread-safe approach and began looking into the Queue module.
I've ended up with something like this...
def worker():
   while q.qsize != 0:
      cmd = q.get()
      # kick off a bash command that zgreps files from different servers
      p = subprocess.Popen(cmd, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
      results.extend(''.join(p.stdout.readlines()).split('\n')[:-1])
      q.task_done()
NUM_WORKER_THREADS = 10
results = []
q = Queue.Queue()
for i in range(NUM_WORKER_THREADS):
   t = threading.Thread(target=worker)
   t.daemon = True
   t.start()
""" Code to generate input commands needed here """
for c in commands:
   q.put(c)
q.join()
""" Post processing of collected *results* array"""
After putting some thread-pool constraints around my program, and also checking in each thread if there is anything still in the queue, my results are inline with what I would expect. After testing, the results match the output of a single threaded approach (except it is much faster).
My questions are as follows:
  1. Is my approach thread-safe? Is there any chance one of the 10 worker threads could overwrite anothers attempt to extend the results array? I am worried that I have just decreased the chance of overwriting to take place, by allocating a smaller thread pool to handle the input, but have not actually solved the problem.
  2. I understand from reading that queues are supposed to be thread-safe. However, when I eliminate thread pools and don't check for the queue size in my threads, I can reproduce the same problem I was having before with large volumes of input. Can someone explain why that is?
gnat
  • 21,442
  • 112
  • 288
Elias51
  • 43
  • you don't have pre-baked thread-pools? your implementation of queue may not be thread safe – ratchet freak Oct 15 '14 at 14:25
  • Try `from multiprocessing.pool import ThreadPool` and `import Queue`, and in no time you'll stop reinventing wheels and start solving your problem. Have some worker functions running on your thread pool, send tasks to workers using one queue, send results back to the main thread using another queue. – 9000 Oct 15 '14 at 14:30
  • What version of python are you running? – Ampt Oct 15 '14 at 15:10
  • @Ampt Python 2.7.3 – Elias51 Oct 15 '14 at 15:22
1a. Is my approach thread-safe?
No because your results isn't thread safe but is being read and written by many threads. Consider turning this into a Queue as well.
1b. Is there any chance one of the 10 worker threads could overwrite anothers attempt to extend the results array?
Yes, that's exactly what could happen, which is why you should avoid using an array in that manner when threading.
You really should be using the prebaked Threading Pool to do your work. It should make your life a lot simpler. It takes in a function to call, and a list containing all the variables it should be called with, and then distributes the list of work among the threads. The only catch is that the function you are calling can only be passed one parameter, but since you're only using one you can adapt your code fairly easily
For example:
from multiprocessing import Pool
def do_work(cmd):
  # Not sure if this can be done better. Not clear what command you're running
  return ''.join(p.stdout.readlines()).split('\n')[:-1]
p = Pool(NUM_WORKER_THREADS)
results = p.map(do_work, commands)
As a side note, you can always get around the 1 argument limit by simply packing all your necessary args into a tuple and then unpacking them at the start of the method. Tuples are cheap in python.
For example if you had a function do_work that took two commands as follows:
def do_work(cmd_one, cmd_two):
  p = subprocess.Popen(cmd_one, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
  p2 = subprocess.Popen(cmd_two, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
  return ''.join(p.stdout.readlines()) + ''.join(p2.stdout.readlines())
we could rewrite it as follows:
def do_work(commands):
  cmd_one, cmd_two= commands
and change our main method to look like the following:
results = p.map(do_work, [(x, y) for x in command1_list for y in command2_list])
In this way, we package both our variables into a tuple for the call, and then immediately unpack them when we need them.
Ampt
  • 4,605
  • 45
  • Thanks for the response. I have implemented something like this but am not clear on how this is threaded given multiple command arguments. I essentially implemented what you have with a loop around the p.map as follows: `for c in commands: results.extend(p.map(execute_query, (command,)))` However, after running, it seems like it executing in a single threaded fashion. Executing queries one at a time instead of 10 at a time. Is there something I am missing? – Elias51 Oct 15 '14 at 23:07
  • So in this example, commands is a list, and the map automatically will split it up among the threads in the pool. – Ampt Oct 15 '14 at 23:09
  • Give it a try without any looping. Just put a list of strings in as command and try it out. – Ampt Oct 15 '14 at 23:09
  • Will do and report back. Thanks for the quick reply! – Elias51 Oct 15 '14 at 23:10
  • Confirmed! So final question. All I am doing is using the multiprocessor threadpool - initial results suggest this is thread safe. Is this all I need to do, is queueing and all that fun handled within this methodology? The discussion here seems to suggest so: http://stackoverflow.com/questions/6893968/how-to-get-the-return-value-from-a-thread-in-python – Elias51 Oct 15 '14 at 23:23
  • Yep! The pool takes care of all the thread safety for you! – Ampt Oct 15 '14 at 23:26
  • Awesome - thanks so much for your help and guideance on this topic. Answer awarded! – Elias51 Oct 15 '14 at 23:35
