After getting into a "heated discussion" with someone, I figured I'd ask this question for the sake of posterity. I'm willing to be corrected if my assumption is incorrect but I'd like to hear a third-party opinion by someone with more credibility than myself.
Let's assume that we need to calculate and store numeric values which are expressed in a decimal format. However, all numerical inputs and outputs must fit within a specific range of values. Also, decimals are important but we will never be interested in any value less than a specific decimal place. This is true for any calculation. If a calculation results in value containing significant digits under the 10^-8 range, they are essentially 0. Likewise, if the value is above our upper bound, then this is considered an error-case.
Considering these fixed constraints, which will never change, is it better to use a traditional Decimal(s, p) data type or to use an Integer type that can contain all values represented by shifting the value s-fixed decimal digits to the left? For instance, for efficiency and accuracy, should we use integers in the range of 0 to 2,100,000,000,000,000 to represent all values between .00000001 and 21,000,000 or should we use decimals defined as (8, 16)?
CLARIFICATION
My specific discussion was regarding data types within MySQL. I'd prefer a generic response, assuming that most decimal representations are stored in a standardized format. However, if there is no reliable "standard" for decimal type definitions, consider this question as it relates to MySQL.
Jonathan Eunice
  • 9,710
  • 42
RLH
  • 533
  • what kind [Decimal](http://en.wikipedia.org/wiki/Decimal_data_type) and [Integer](http://en.wikipedia.org/wiki/Integer_%28computer_science%29) are you asking about? – gnat Oct 15 '14 at 13:51
    should temporary results be in as high accuracy as possible or immediately rounded to the results accuracy? – ratchet freak Oct 15 '14 at 13:52
  • @gnat If a context is necessary (assuming this isn't moderately standardized) I'd say I'm using a SQL decimal type. Specifically MySQL. Integers are the same but can be of any standard byte-width (i.e. ints (4 bytes), bigints (8-bytes) even smallints,(2).) – RLH Oct 15 '14 at 13:55
  • @ratchetfreak I think the line *"If a calculation results in value containing significant digits under the 10^-8 range, they are essentially 0."* answers your question, does it not? all values, even intermediaries within multi-step calculations, must evaluate to numbers in the expressed range. – RLH Oct 15 '14 at 13:56
  • Personally, I'd go with decimals because I think it would make the code easier to read and eliminate conversion errors. I'm sure someone else will post the opposite opinion and back it up eloquently. – Dan Pichelman Oct 15 '14 at 13:57
    even when a value in the range 10^-8 is later multiplied with a value in the 10^20 region? – ratchet freak Oct 15 '14 at 13:57
  • I see. Consider [edit]ing your clarifications into the question, for some readers tend to ignore comments – gnat Oct 15 '14 at 13:59
  • @ratchetfreak Consider such a case an error case and proper handling is out of the scope of this exercise. – RLH Oct 15 '14 at 13:59
  • Also, to be clear, calculations can result to values under 10^-8 but the result always evaluates to 0. – RLH Oct 15 '14 at 14:02
    @RLH You make a number of assumptions that strike me as unwise. A lot of calculations can easily take a detour outside the range your inputs and final results lie in, especially if the order of operations is subject to change or the actual formula is transformed algebraically. Requirements do change more often than one thinks (even if you take this very observation into account). The answer to what you wrote here may very well "ints are preferable" but in your *actual* situation the opposite may be the case. –  Oct 15 '14 at 15:18
  • Most importantly: [What Every Computer Scientist Should Know about Floating Point Artithmetic](https://news.ycombinator.com/item?id=4815399). If you get bored: [Why Floats Suck](https://news.ycombinator.com/item?id=2506918), [There are only 4B Floats](https://news.ycombinator.com/item?id=7135261), [Take Care...](https://news.ycombinator.com/item?id=5538365) – earthmeLon Oct 16 '14 at 18:44
Use decimals. Consider
2.00 * 3.00 = 6.00 (as-is)
200 * 300 = 60000 (hmm: /100)
There is no need to think "more optimal" - the computer is likely to do it optimal too. All catches dealt with.
It is especially cumbersome in SQL, to consistently use your own integers correctly, maybe introducing your own function, but at the same time preventing SQL to optimize some queries which would have been column based.
Also consider that at some moment the data must be used in code. And then exactly the same problem repeats itself: multiplication. And automatisms like ORM become more complicated.
Joop Eggen
  • 2,011
For database storage, decimals.
TL;DR Backstory
If you were processing these results primarily in main memory, it might be a toss-up. There are many small-range floating point / decimal problems that can be solved with scaled integers and fixed point math. For example, I solved this this recent partitioning problem from Stack Overflow in the integer realm, then returned the answer as floating point. I've also seen many text formatting and graphical layout algorithms use similar approximations. The integer math is simple, very fast, and works well.
But, without further constraining your use case, there are drawbacks, such as it becoming your responsibility to
  • Provide any mathematic functions like sin and sqrt you might need.
  • Convert from your custom-scaled integers to other types you might need, like formatting into strings, or into floats and proper decimal types.
Those are "a simple matter of effort," but the details of getting those things right can be vexing and distract you from your primary coding goals.
Add to this that you are specifically interested in storing these values in a database. That implies permanence and a long data lifetime. If there's anything we've learned about fixed-precision data in this industry, it's that requirements will change over time, and then you'll have to change your data, and the apps that use them. Think Y2K or financial market decimalization. Fixed-point seems a solid foundation, but in a few years your decimal precision needs might change. The scale chosen for printer internals when 300dpi printers seemed impossibly high-resolution wasn't so precise when 1200- and 2400-dpi printers rolled in a few years later.
So, if you're interested in efficient in-memory representations fitted to specific problems, fixed-point can work well. But if you're storing data over time, decimals make for a richer, more future-proofed representation that someone else takes the responsibility for making work, getting you back to your own development tasks.
Jonathan Eunice
  • 9,710
  • 42
  • FYI, my use-case relates to bitcoin. If you are unfamiliar, after all bitcoins are created, there will only be 21,000,000 and bitcoins cannot be divisible to any relevant value less than .00000001. In this context, you can store values in a decimal(8,16) field, but you will always be converting from a decimal. If you have a value in your db that you will need to pass back to bitcoin for bitcoin transaction, you will need to convert back to integer values. I recommended to always store the value as an integer, which started the argument. – RLH Oct 16 '14 at 00:39
    That the APIs/services you deal with will need integers definitely argues toward the integer side. For money, you won't need `sin`, `sqrt`, and friends. Monetary systems also change slowly, so a given precision can hold constant for years. But, even monetary systems aren't set in stone. National financial markets shifted trading units and precisions many times in the last two decades. I might still store decimals in the persistent db for future-proofing, and to have easily human-readable values (to ease formatting and error checking). But it could go either way. – Jonathan Eunice Oct 16 '14 at 18:34
