Scalability isn't the only issue in making this choice (and I do know of successful databases with trillions of records so databases are more scalable than you think). Nor is it probably the most important.
First you need to look at the meaning of the data. Something like Facebook is tied intrinsically to its application and thus putting the logic there isn't as risky as a business application which has to get its data from imports, database jobs, user data entry from several different applications including some that perhaps the business has no control over. So the risk to data integrity is the first and most important thing to consider when making this choice.
Also how the data will be used and in what environment is critical. How is the information audited? Are there regulatory requirements? How is the reporting done? Do I need to be able to reuse the logic in a different reporting system as well as in the user application? If so the logic needs to rest outside of the application. Do I need to do exports of the data and how is that affected by the logic being in the application. Does that mean the people writing the reporting and export code will not have the ability to see what the logic is because they don't have access to application code? That can be a major problem.
Another consideration is the scalability which includes the performance. How much scalability do you need? Very few things need the scalability of a Facebook. How much performance do you need? Designing for scalability when you will never need it leads to less than optimum results. Will the methods you use to put logic in the application have a negative impact on database performance (many ORMs for instance write terrible database code).
Then there is the argument about less time for development which is ridiculous. If you know what you are doing, putting the logic in the database does not take more time than putting it in the application. It is just that most application developers aren't SQL specialists. However, is saving the devs time to get better at SQL really a plus? No it is not because that choice almost always comes at a cost of performance on the database and at the cost of data integrity.
What I am trying to say is there is no one size fits all. There are some applications where putting the logic in the application makes sense and some where it does not, but thinking there are only one or two critical factors to consider when making the choice is generally a mistake.
