Below is a sample code i captured from android doc
Per service instance onCreate will be called only once. Ref: here and here
The synchronization and singleton doesn't make any sense to me in this circumstance. Very recently i asked another question on google document here
If this is again wrong, probably i need to limit myself to just take calling conventions from their documents and ignore their logic.
Sorry to running through Google doc with community in quick succession. I just want to correct myself on how much i should take from these documents.
public class SyncService extends Service {
// Storage for an instance of the sync adapter
private static SyncAdapter sSyncAdapter = null;
// Object to use as a thread-safe lock
private static final Object sSyncAdapterLock = new Object();
* Instantiate the sync adapter object.
@Override
public void onCreate() {
* Create the sync adapter as a singleton.
* Set the sync adapter as syncable
* Disallow parallel syncs
synchronized (sSyncAdapterLock) {
if (sSyncAdapter == null) {
sSyncAdapter = new SyncAdapter(getApplicationContext(), true);
