I don't know if there are any accepted names for these patterns (or anti-patterns), but I like to call them what I call them here. Actually, that would be Question 1: What are accepted names for these patterns, if any?
Suppose there is a method that accepts a bunch of parameters, and you need to check for invalid input before executing actual method code:
public static void myMethod (String param1, String param2, String param3)
Hurdle Style
I call it so because it's like hurdles a track runner has to jump over to get to the finish line. You can also think of them as conditional barriers.
if (param1 == null || param1.equals("")) {
// some logging if necessary
return; // or throw some Exception or change to a default value
if (param2 == null || param2.equals("")) {
// I'll leave the comments out
return;
if (param3 == null || param3.equals("")) {
return;
// actual method code goes here.
When the checks are for a certain small section in a larger method (and the section cannot be moved to a smaller private method), labelled blocks with break
statements can be used:
// method code before block
myLabel:
if (param1 ... // I'll leave out the rest for brevity
break myLabel;
if (param2 ...
break myLabel;
// code working on valid input goes here
} // 'break myLabel' will exit here
// method code after block
Fence Style
This surrounds the code with a fence that has a conditional gate that must be opened before the code can be accessed. Nested fences would mean more gates to reach the code (like a Russian doll).
if (param1 != null && !param1.equals("")) {
if (param2 != null && !param2.equals("")) {
if (param3 != null && !param3.equals("")) {
} else {
// some logging here
} else {
} else {
It could be re-written as follows too. The logging statements are right beside the checks, rather than being after the actual method code.
} else if (param2 == null || param2.equals("")) {
} else if (param3 == null || param3.equals("")) {
} else {
Question 2: Which style is better, and why?
Question 3: Are there any other styles?
I personally prefer hurdle style because it looks easier on the eyes and does not keep indenting the code to the right every time there's a new parameter. It allows intermittent code between checks, and it's neat, but it's also a little difficult to maintain (several exit points).
The first version of fence style quickly gets really ugly when adding parameters, but I suppose it's also easier to understand. While the second version is better, it can be broken accidentally by a future coder, and does not allow intermittent code between conditional checks.
