How is runtime-generated machine-code (such as the output of a JIT), actually executed by the CPU if the CPU/OS has an Execution Disable bit?
As far as I know, many modern processors and Operating Systems include support for an NX bit, (including Intel and ARM), which prevents machine code that is stored at any address other than the code section of a compiled binary from being executed. Clearly, this is a nice security advantage, because it prevents shell-code injection attacks.
But how do JIT engines, like LLVM, which dynamically generate machine-code, get around this?
Siler
  • 421
  • Take a look at the implementations of Memory::allocateMappedMemory to see how it is done in LLVM. - [For *nix](https://github.com/llvm-mirror/llvm/blob/master/lib/Support/Unix/Memory.inc) - [For Windows](https://github.com/llvm-mirror/llvm/blob/master/lib/Support/Windows/Memory.inc) – zr01 Sep 08 '14 at 19:51
On Linux and many Posix systems, an application can change the protection of some range of the process address space in virtual memory using the mmap(2) and mprotect(2) syscalls.
So the JIT engine could use these (probably before emission of the machine code, but perhaps after it).
BTW, on some architectures, you may need to inform the CPU cache about newly available machine code segments, e.g. __builtin_clear_cache of GCC.
Basile Starynkevitch
  • 32,434
  • 84
  • 125
