I am learning ZeroMQ and came across the Majordomo Protocol. I am wondering if I'm understanding this correctly, is the use case the same as.. for example.. the Microsoft Azure AppFabric service? Would I use Majordomo if I wanted to create an AppFabric-like servie bus? Or would I do Pub/Sub+Request/Reply?
If you are not familiar, azure service bus is a way to connect applications to services (or applications to applications, etc) -- at least for the purposes of this discussion:
Azure AppFabric Service Bus
Does it seem like this is a Majordomo protocol use case, or am I looking at a different pattern here (the bottom "direct-connection" line notwithstanding). How would eventing work (a worker initiated message)?
(EDIT) Thanks Adam. Distilling the question down to its essence, if I were to implement the Azure AppFabric messaging protocol with ZeroMQ, would I be using the Majordomo protocol, or would another pattern be more appropriate?
Also as reference, link to ZMQ Majordomo: http://rfc.zeromq.org/spec:7
Will I Am
  • 225
  • You have multiple questions that you are asking. Please try to narrow the scope to a single question (e.g., What are the differences between the Majordomo protocol and Azure's messaging protocol?) – Adam Zuckerman Sep 06 '14 at 04:10
  • I clarified. Hope it is satisfactory – Will I Am Sep 08 '14 at 01:19
0 Answers0
