I have often heard unit tests help programmers build confidence in their software. But is it enough for verifying that software requirements are met? I am losing confidence that software is working just because the unit tests pass.
We have experienced some failures in production deployment due to an untested\unverified execution path. These failures are sometimes quite large, impact business operations and often requires an immediate fix.
The failure is very rarely traced back to a failing unit test. We have large unit test bodies that have reasonable line coverage but almost all of these focus on individual classes and not on their interactions.
Manual testing seems to be ineffective because the software being worked on is typically large with many execution paths and many integration points with other software. It is very painful to manually test all of the functionality and it never seems to flush out all the bugs.
Are we doing unit testing wrong when it seems we still are failing to verify the software correctly before deployment? Or do most shops have another layer of automated testing in addition to unit tests?
Peter Smith
  • 2,587
  • It is correct that unit tests focus on individual classes. Automatic tests that test different classes and their interactions are called integration tests. Integration tests can be an extra layer of automatic tests. In addition to integration tests, many products are systematically tested by a team of test engineers before shipping. – Giorgio Aug 22 '14 at 18:43
  • "It is very painful to manually test all of the functionality and it never seems to flush out all the bugs.": Do you use well-defined test protocols? Are the test protocols based on the requirements specification? – Giorgio Aug 22 '14 at 18:46
  • @Giorgio We don't have a well defined test protocol. We have a QA department, but they're often too understaffed to properly test all software changes. And sometimes, they know less about our software then the programmers do, which often doesn't lead to very good testing. – Peter Smith Aug 22 '14 at 18:49
    Well, then maybe you need a proper team of test engineers who define test protocols based on the requirements and then execute the tests based on the protocols. Free testing (be creative and imagine what the user might do) can also discover several unexpected bugs. In my 6-year long experience I observed that a proper team of test engineers is very important to ensure good quality. – Giorgio Aug 22 '14 at 18:53
  • When you have bugs, are they due to interactions between objects which weren't caught by unit tests because they were mocked to return what was expected, as opposed to what was actually returned? – Winston Ewert Aug 22 '14 at 19:36
  • [An answer explaing pros and cons of ATDD](http://programmers.stackexchange.com/questions/223991/is-it-sufficient-to-use-acceptance-and-integration-tests-instead-of-unit-test/224045#224045). [And another one with a slightly different perspective](http://programmers.stackexchange.com/questions/182391/functional-testing-before-code-checkin/182408#182408) – dietbuddha Aug 23 '14 at 04:30
6 Answers6
In general no. For toy programs (say solutions to Project Euler problems), sure.
This is before getting into a religious discussion of what are unit tests (if it uses a file system object, is it a unit test? Let the inquisition begin!)
For N-Tier applications, where N > 1, integration tests are needed, and even they may not actually be suitable for requirements verification, as most integration tests are between two tiers, and not normally end-to end testing. Most end-to-end testing (a minimal test for most requirements) is usually done as / in conjunction with system level test.
On a large project I worked on, we had CUT (Code and Unit Test) done by the developer. The build code then went into Integration and Test (I&T), where some minor requirements that could be verified (warning alerts will be displayed in 'FUNKY_RED' in the admin console). When it passed that, it was released to System Level Test (SLT). The 'Requirements Testing' was done in SLT, where they had a mirror of the operational site. Finally, it was deployed and went to Acceptance Test.
Some of this would change, depending on the scale of the project. But in my experience, anything with more than one module/jar/library will not be sufficient with just unit tests.
Add in testing a GUI, and it gets really unlikely that a you can have 100% confidence without live interaction.
EDIT: Looking back, I think that take away is that for complex systems, simple testing (like unit testing) is not going to be sufficient for requirements validation. Complex systems will require complex (sophisticated?) testing to verify.
Kristian H
  • 1,261
  • And that's why, in our workplace, we implement SIT (System Integration Test) and UAT (User Acceptance Test). Anything passing unit tests should go through these phases before being deployed in production. More often than not, they come back to the developers with failures during SIT and UAT. – ADTC Aug 23 '14 at 02:43
  • I&T and SLT are done by the same, or other developers or other non-developer staff? Who performs acceptance tests? – Peter Smith Aug 23 '14 at 16:22
  • Depends on the organization. Where I worked, i&t was done by a developer, but not the one who did the change. CUT was done by the assigned developer. SLT was a separate test group, with formal test procedures that mapped to requirements. – Kristian H Aug 23 '14 at 16:41
You have several things to consider:
  1. Requirements must be testable. If they're not testable, then you can't verify them with tests.
  2. Unit tests are not proof of correctness, mainly because they cannot provide 100% code coverage in any practical way.
The first bullet is fairly easy to correct, if difficult to implement in practice: make your requirements testable. The best way to do that is to define an acceptance test at the same time that you write the requirement.
Bullet two just raises the question, "How do I write more reliable software?" That, my friend, is the subject of a lifetime of study.
However, from a testing standpoint, you can improve the situation by adding Integration Tests and System Level Tests. Unit tests, on their own, are often insufficient to completely describe a rigorous test suite. Work with your stakeholders to define and write tests, the scope, cost and benefits of which everyone understands.
Robert Harvey
  • 198,589
  • 55
  • 464
  • 673
  • Yes, it seems the questioner's organisation has fallen into the fallacy that unit tests are the only kind of automated test ("do most shops have another layer of automated testing in addition to unit tests?"). So they've excused themselves from the responsibility to test the requirements of anything other than units. Since most of the requirements are written before the units are even designed, this means they're not testing anything of practical consequence other than regression within a single unit! – Steve Jessop Aug 23 '14 at 01:09
To fully test a system, you would have to put it through every possible series of input conditions, so for any non-toy system, no there's no way any testing system should be expected to catch all errors.
However, this is a case where perfection is the enemy of "good enough". If a testing system reduces the chance of shipping a defective product, or reduces the number of shipped defects, or reduces the amount of time it takes to reasonably test a system before it ships, then it has value.
Simply having "large unit test bodies that have reasonable line coverage" is no guarantee of bug-free code. However, it's probably a lot better than no testing system at all.
Note that unit testing is only one type of software test. It wouldn't hurt to create a few automated integration tests either. Not only that, when I am about to release a new version of software I always manually check that I can do a couple critical functions, just in case.
Scott Whitlock
  • 21,874
  • 60
  • 88
The phase "unit test" began as a description of testing individual functions and other small bits of code / capabilities. If that is all you are testing--bits of your system, in isolation from one another--it is no wonder that you are losing confidence in your tests to be a fair measure of overall code quality or "does it do what it's supposed to do?"
Very narrow testing helps a little, but just a little. It's great that you aren't getting production failures that trace back to things that have been tested. The problem seems to be the white space in between--the untested execution paths, the combination of elements that happens when all of the parts come together that are not currently tested. Without being too Pollyannaish, there is your problem. Or a good part of it, at any rate.
This is perhaps heresy, but it's worked well for me: Unit tests are no longer about isolated, narrow units. They are a general purpose automated testing facility that can and should test not only individual functions, classes, and objects, but combinations of them, at varying levels of composition.
I may be running PHPUnit or py.test or whatever the local "unit test" framework is, but I eagerly add tests up to and including tests of the entire integrated application or service. I run complex examples of the entire app functionality, and do so not just against simple data cases, but also against some gnarly, ugly, complex edge-cases.
It isn't as easy to test that way. It requires creating some mock objects, and/or building entire virtual machines and populating them with servers, data sets, and other glue logic just to run the tests. It's more work to set up that test scenario, but with virtualization and cloud instances, tools like Fabric and Vagrant make it doable in ways that it just wasn't, five or so years back.
It can even be complicated to determine if a test succeeded or failed. If you're used to testing small functions, it's hard to see why--but start trying to judge whether you've properly manipulated a complex data structure and it becomes more clear. It can be even worse if you're trying to see a particular path through a GUI or web app to ensure it "did what it's supposed to do." But with modern tools, it is possible--and the results are extremely helpful at exercising the whole system.
Testing can never be a proof of correctness under all possible conditions. But exercising your app or service as a whole, with complex and edge/corner case examples designed to stress your logic...first it will show you where a lot of your bugs lie. ("The truth will set you free — but first it will make you miserable.")
But as you fix those and your system is executing hard cases successfully and routinely, then your confidence in its correctness and robustness will grow. As you find new bugs and fix them, you will add tests for them, and other cases like them you hadn't previously considered. On subsequent passes at the testing job, you'll find new things you want to test, or new variants you want to test against. You add them in, and next run, you're testing even more of the total system.
If anyone wants to argue that I'm not really unit testing--that I'm doing some form of integration, module, or system testing--well whatever! I use the same (unit testing) frameworks, test runners, "did it pass?" reporting that I would for testing a 2-line function. If you want to give fancier names for some of the tests, knock yourself out. What I care about is that the tests are automated, that I can run them easily for every software build, and that they test as much of the total functionality as possible.
Long story short, instead of losing faith in testing, double down on it. Do the testing that you need, but aren't currently doing. Test things together, in ever more challenging and complete combinations, against ever more execution environments. You'll be amazed at the bugs that shake out, and at how much you learn about your system interactions as a result. Untimately, you'll be amazed at how you move with confidence from version to version, because your shakedown has been real and systematic.
Jonathan Eunice
  • 9,710
  • 42
  • How long does it usually take for you to implement this for a new software system? I understand it could have a lot of value and not necessarily be difficult to maintain for an existing software system with existing integration tests. – Peter Smith Aug 23 '14 at 16:19
  • It depends entirely on how challenging the tests are to construct. The provisioning of new virtual machines/environments has a learning curve associated, but once you've got the scripts/ability to do provisioning, that part is actually very simple. Mechanically determining whether a complex/composite use has done what you want...not always easy. If you want a shortcut, build a few simple and a few edge/corner case tests first. The simple ones prove the test rigs work; the edge cases exercise the app crazy-hard. When you get those working, you gain enormous confidence in the code. – Jonathan Eunice Aug 24 '14 at 23:51
  • Another benefit of testing very high up the food chain: When things break (not if, when) you'll start tracing those failures back and find individual modules (sometimes, groups of modules) that aren't doing what you think they should. I.e. it will identify your quality problem areas. Then you start adding intermediate-level tests there, and running those problems to ground. Do that a few times, and you've adaptively both fixed and qualified the parts of your app/service that needed it most. – Jonathan Eunice Aug 25 '14 at 00:22
Indeed, as you have found, unit tests are frequently inadequate for this.
What you need is integrated testing that will look to test:
  • dependencies
  • interactions
  • different viewing devices / platforms / versions
You may also need to revisit unit tests and review how much sad path (as opposed to happy path) is currently being tested. Developers frequently focus on the happy path but often do not anticipate or take the time to cover complex cases and all the sad paths.
Michael Durrant
  • 13,101
  • 60
-1
In my experience, this is caused by poor class design, and occasionally bad unit test writing.
In an (achievable) ideal world, you unit test class A: it takes the right input and produces the right output. Then you unit test class B: it takes the right input and produces the right output. If the "right" output of class A is fed as the "right" input to class B, then it'll just work.
The only way that things go south is if your class defines some nuanced definition of "right" due to implied coupling either in data or time or sequence or... This is where good class design comes into play. By reducing your coupling and making your "right" input clearer, then there's less chance that people can screw that up.
The other thing that can happen is that your unit tests work with some naive use of "right" that doesn't test boundaries, or actually exercise your code while still getting code coverage. Bad tests will yield bad results - the worst of which will be the passing test that provides no confidence.
Telastyn
  • 108,850
  • 239
  • 365
