When I execute the following loop :
 unsigned m;
 for( m = 10; m >= 0; --m ){
        printf("%d\n",m);
the loop doesn't stop at m==0, it keeps executing interminably, so I thought that reason was that an unsigned cannot be compared to 0. But when I did the following test
unsigned m=9;
if(m >= 0)
    printf("m is positive\n");
else
    printf("m is negative\n");
I got this result:
m is positive
which means that the unsigned variable m was successfully compared to 0.
Why doesn't the comparison of m to 0 work in the for loop and works fine elsewhere?
S.E.K.
  • 145
You should compile with all warnings enabled.
A test like m >= 0 is always true if m is unsigned; so
if(m >= 0)
else
can be optimized as
A recent version of GCC, invoked as gcc -Wall (or gcc -Wall -O1) would have warned you.
And a test like m >0 is the same as m != 0 (or just m)
And your for ( m = 10; m >= 0; --m ) loop is understood as for(m=10; TRUE; --m) so loops indefinitely. Mabye you wanted for (m=10; (int)m>=0; m--) , then the test would fail when m becomes large enough to not fit in an int (without overflow to negative int). But such a (int)m>=0 is ugly and unreadable, so avoid it.
Basile Starynkevitch
  • 32,434
  • 84
  • 125
  • But what's the advantage of using unsigned variables instead of signed ones? – S.E.K. Aug 18 '14 at 09:52
  • A good answer for my question would be this post : http://programmers.stackexchange.com/questions/225949/using-unsigned-integers-in-c-c – S.E.K. Aug 18 '14 at 10:17
