My understanding of how TDD should work is that you write a failing test for the next bit of functionality you want to add to a function or object, code until the test passes and then write the next test. Is it ever ok to write tests that pass with the code as is?
One example of that happened today. I was writing a function that could Manchester encode an arbitrary number of bits. I wrote failing tests for encoding one single bit and coded until it passed, then wrote a failing test for passing two bits to the function and coded until it passed. But the solution I used to handle two bits made the code work for any number of bits. Because passing a byte to the function will be it's most common use, I added a unit test to make sure it worked for 8 bits, which did in fact pass.
Did I violate TDD principles? Is there anything wrong with adding redundant tests just for my peace of mind? I understand part of the problem is that I could have written a faulty tests and would never know because it didn't fail in the first place, but I'm not sure what the alternative is.
