My team is new to versioning and we're trying to keep things simple, as to not overwhelm ourselves with tools-headaches. Also, our product can't be compiled and run locally, so our work is actually more like the whole team modifying a single test server.
So we're thinking that we don't want to make too many branches while we work -- branching means merging, and merging requires practice to do right consistently. (We have to use use TortoiseSVN "because reasons" so better alternatives are not relevant now.)
Is it a "newbie mistake" to think that having many branches is a bad thing because it makes the landscape complicated; of fear that having many branches could more easily confuse us when we need to merge things back together again?
  • _"Unless you are all working out of the same working tree, you are using branches"_ -- so we don't use branches. Thanks. – Torben Gundtofte-Bruun Aug 12 '14 at 12:41
  • So you have a single physical copy of your files and directories, and you're all editing at the same time, in the same place? – Useless Aug 12 '14 at 13:00
  • @Useless: sort of, yes. It's not a conventional build process we could do locally; it's more like a shared DEV server that we all work on while it's running = continuous integration. There's a TEST and PROD server, too, and we think a versioning tool would help with packaging and propagating releases. – Torben Gundtofte-Bruun Aug 12 '14 at 13:11
    So you mean a single _server program instance_, not a _single physical server which can run multiple programs_, right? Because the second case is fine, especially if you can run multiple instances of your software. The former means you have no way to manage conflicts between developers (editing/overwriting the same file, making conflicting changes, etc.). – Useless Aug 12 '14 at 13:55
  • Yep, there's only one DEV instance, and the same in TEST and PROD. can't run several DEV concurrent because of expensive Oracle and WebSphere licensing. – Torben Gundtofte-Bruun Aug 12 '14 at 14:03
  • Oracle offers a free [express edition of their database](http://www.oracle.com/technetwork/database/database-technologies/express-edition/overview/index.html). It lacks many of the features the paid editions provide, but most of these features are about optimization and scalability - very important features for the production(and QA) server, but you might be able to live without them in dev instances that run on individual developers' machines. As for WebSphere - I don't see a free edition on their website, but you might be able to find a freeware application server that can run your project. – Idan Arye Aug 12 '14 at 15:28
The policy of deliberately refusing to branch is usually a mistake, but I don't think branching is feasible in your case. Not because you are using SVN - which is the usual reason for not using branches, since SVN's handle on branches is especially crappy, even compared to SVN's general crappiness - but because of this:
This, IMO, is your main problem, and as long as you don't fix this - I don't think you can use branching even if you wanted to. Different developers can't work on separate branches since they are forced to share a working copy. If one developer checks out a branch, that branch will be checked out for the the developers, which means that you miss the main advantage of branching - allowing multiple developers to work on different features of the same project without getting between each other's legs.
So, you can't use branches to coordinate the collaborations, but solo developers(that use SCMs that are not total garbage - which is not your case here, but let's ignore it for the point of the debate) also use branching - e.g. to test new features that may or may not be merged or to explore the system in a scrapable branch.
Can you use branches in such a way? Well, even if you are OK with moving the whole team to a feature branch or to a scrapable branch - how do you plan to coordinate it? Will you use email, or install a PA system where you can announce WE ARE NOW MOVING TO FEATURE X'S BRANCH? And what will you do when some dev is in the middle of something in the current branch? Will you make them roll it back, or make the entire team wait for that developer to finish?
Do you really want that headache?
Another point to consider - branching usually needs some level of cleanness in the build process and project tree structure, so artifacts of one branch won't leak to other branches when you switch branches. SCMed projects usually have that - or else they wouldn't be able to build on all the machines of all the developers - but seeing that your project can only build on the test server I doubt you have that minimal level of cleanness. Oh, your branches will probably work - at least in the beginning, until a leaky artifact will surprise you with some weird, hard-to-detect bugs.
Idan Arye
  • 12,032
  • 40
It is certainly a mistake, but not necessarily only a newbie mistake.
At my last job (a highly competitive motorsports job) my boss was adamant about avoiding branching. He had about 20 years experience and still thought it was a bad idea.
I completely disagreed with him and challenged his misconceptions. There are times where branching isn't worth the potential hassle it brings. Yet, there are other times where it is clearly the only sane solution (eg, two teams doing two parallel but separate iterations of work on the same source code). Just like everything else in life, you shouldn't have a blanket rule about it.
So, yes, it's a mistake. No, it's not just a newbie mistake, though it should be.
MetaFight
  • 11,549
  • 44
  • 75
Keep in mind that the only purpose for branching is isolation. You branch when you want to be able to make changes in location A without impacting location B. Having a branch adds work, so you want to create a branch when the benefit of having the branch outweighs the pain of the overhead involved.
For example, creating a branch to fix a small bug is crazy - the work involved in creating a branch and merging is probably going to be way more than what it takes to fix the bug. On the other hand, you absolutely want a branch for a major release. You need to have a stable code base with controlled fixes.
Anything in between is a judgement call and really depends on the size of the team and how the team works. Here, I work on a team of 3 people and we only have the mainline and release branches. If I was working in a group of 10+ people, I'd expect that we'd have more branches.
Also keep in mind that branch depth is important because it dictates how many merges you need to do. One common setup is to use individual developer branches that hang off of an integration branch, which then hangs off of main. In this scenario, a bug fix from a developer branch going to a release needs to be merged, built, and tested 4 times (dev->integration->main->release). That's a lot of overhead, so there better be tangible benefits from having those branches.
17 of 26
  • 4,818
  • This is an important point. We would use branches as a way to be able to add fixes to released versions while working on the next version as well. Branches for past releases can be improved and delivered as updated minor releases. – Torben Gundtofte-Bruun Aug 12 '14 at 14:39
  • A good answer although I would have loved some specific considerations for OP's case – Marco A. Aug 12 '14 at 17:18
  • I make branches for small bugs all the time. It’s not “crazy” to do so as long as your VCS makes branching and merging sufficiently quick and easy (I use Git, which does), and the isolation is worth it. – Marnen Laibow-Koser Nov 07 '19 at 21:21
