13
Reactive programming and MVVM are two approaches that can address the problem of separating the domain layer from the UI.
  • MVVM does this by defining a viewmodel, which is a data structure mapped to UI components. The UI display the data, and maybe update it when user occurs.
  • a reactive framework defines a graph of observables which notify the UI that some piece of data has changed
Reactive frameworks are gaining mind share, both in mainstream platforms (with Rx in .net & java, react.js) and more experimental places (FRP in haskell).
I have mainly used MVVM with angular, and I find the simplicity to expressiveness ratio quite satisfying, although I have only worked on small/medium projects with it.
What does a reactive framework buys the developer that mvvm don't?
Is there really a difference? For example, knockout.js is advertised as a mvvm framework, but has a reactive feeling in its interface:
this.firstName = ko.observable("John");
this.lastName = ko.observable("Smith");
this.fullName = ko.computed(function() {
    return this.firstName() + " " + this.lastName();
}, this);
Den
  • 4,827
  • 32
Simon Bergot
  • 7,930
  • 35
  • MVVM is a **pattern** to separate the concern of presentation from domain. Reactive frameworks are **tools** that can be used to achieve this separation pattern. They aren't exclusive. – Alex Aug 05 '14 at 08:56
  • @AlexG Well, there are tools that coordinate the communication between a viewmodel & the UI. I would call those MVVM frameworks. – Simon Bergot Aug 05 '14 at 09:10
  • The point stands - KnockoutJS **uses a reactive framework** to enable the MVVM separation of concerns. AngularJS **uses dirty-checking** to enable MVVM. They are just different ways of achieving the pattern. Perhaps your question is *"What does the Reactive paradigm achieve in an MVVM framework that the Dirty-Checking technique doesn't?"* – Alex Aug 05 '14 at 09:15
  • @AlexG so you would say it is an implementation detail? I think it answers my question. – Simon Bergot Aug 05 '14 at 09:19
  • @Simon: I wouldn't qualify it as an implementation detail, but more as different approaches of communicating changes in the Model up to the ViewModel – Bart van Ingen Schenau Aug 05 '14 at 10:05
Those are different non-competing concepts and they can easily work together to produce a great result.
In layman terms:
MVVM is useful to get away from the codebehind (GUI/model coupling) clutter. Reactive approach is useful to reduce the event/callback clutter.
I would recommend learning a bit about XAML/WPF since Microsoft is the original inventor of the MVVM. Microsoft also produced a very good implementation of Reactive approach: Reactive Extensions.
Here is a decent attempt to combine them:
http://www.reactiveui.net https://github.com/reactiveui/ReactiveUI
Related SO question:
https://stackoverflow.com/questions/1763411/reactive-extensions-rx-mvvm
Den
  • 4,827
  • 32
