For the backstory, I'm developing a GUI application in C#/WPF. I already had in my code quite many instances of
<ComboBox ItemsSource="{Binding Items}">
<ComboBox.ItemTemplate>
<DataTemplate>
<TextBlock Text="{Binding ItemName}"/>
</DataTemplate>
</ComboBox.ItemTemplate/>
</ComboBox>
when I accidentally stumbled upon DisplayMemberPath
during a marginally related StackOverflow search, which makes the above
DisplayMemberPath="ItemName"/>
Now ComboBox
has 158 public properties, and I really doubt that I should read all of their descriptions before even starting to use a ComboBox. On the other hand I'm really afraid of encountering this problem on a larger scale, since this is my first WPF app and I sometimes get the feeling of doing it wrong.
Note that online tutorials apart from the official documentation are very unreliable, often wrong and/or poorly written; at least I found it hard to find a good one. On the other hand, any programming books I've encountered went into too much detail, taking whole chapters explaining things that were obvious to me after the first paragraph, so I skipped a lot of parts.
When using a complex framework or library, how can I avoid accidentally skipping a relevant part of the impenetrably huge documentation, therefore creating unnecessary work for myself?
I don't think this is a duplicate of What kind of process should I use to learn a big system? or How do you dive into large code bases?, because these are about learning a codebase that you have to understand/work on/modify/improve, also assuming that you have access to the code itself. My question is about being a user of a framework, and the task at hand is "given the huge official documentation and Google, efficiently find those parts of the framework that I can use to make my work easier".
