35
I have just begun to learn Django/Python/Web Development. This problem has been troubling me for a while now.
I am creating an application with multiple templates in Django. I have a views.py which is basically just rendering the responses to the respective templates and I have a models.py where I have structured my DB. In one of my templates, I need to upload an image (which I am able to do) and I need to run a logic which is based on the features of the uploaded image (not yet done). This logic involves a lot of heavy calculations. After performing the calculations, the logic should return some processed information (coordinates) to the template.
I have been able to do all this actions successfully in a standalone python desktop application calling python files one after the other. However, since I now want to make this a web application I have begun using the Django framework.
I have done a lot of searching but I am still not able to figure out where exactly should I place this Python file containing all the logic. Should I have another class based file (logic.py) and call it from the view.py? I googled and found that many developers are placing their business logic in their models.py in Django. However, I feel it is intuitively not right since model should exclusively communicate with the back end. Any help would be appreciated.Thanks in advance.
Kilian Foth
  • 107,706
  • 45
  • 295
  • 310
adrita
  • 355
  • possible duplicate of [Where to put business logic in MVC design?](http://programmers.stackexchange.com/questions/165444/where-to-put-business-logic-in-mvc-design) – Bart van Ingen Schenau Jul 16 '14 at 06:22
  • Found an article that discusses this topic extensively (with pyramid in mind, not django). Has some senseable thaughts: http://nando.oui.com.br/2014/04/01/large_apps_with_sqlalchemy__architecture.html – kratenko Oct 13 '15 at 14:25
There are a number of options, depending on what your requirements are:
  1. Add the logic to e.g. the Image model. This is a useful option if you need to store per-image meta data in the database, and each model instance (each image) is processed by itself.
  2. Add the logic as a plain Python Image class, e.g. in a file called image.py. Nothing in Django restricts you from adding logic other than that in the views or models modules. This is a good option if the image logic is a central component of your Django app (e.g. a Image processing app).
  3. Create a separate Python project that provides the logic, then call it from your views. Make sure to install this project in your Django app's Python environment. This option is valid if the purpose of your Django app is to upload and view images, or to show the results of the image processing in direct response to a user's request, but where the image processing could be used by other projects too.
  4. Create a separate app that processes requests asynchronously and is run separately from your Django app. This option is useful if you need to decouple the image processing from the request cycle of the app, process large number of images, or where each calculation takes too much time to solve within a request cycle's time (say within at most 500ms to 1s).
There is nothing in Django that requires a model to communicate with the back end, or rather the database. I think you are mixing the semantics of what Django typically considers a model (namely, an abstraction of one or several tables in the database), v.s. the term model as a design construct (e.g. as in Domain Driven Design).
miraculixx
  • 3,103
Daniel Greenfeld, co-author of "Two Scoops of Django, recommends the business logic should be in the models "when possible, or in the forms if you must." As for Bart's possible duplicate, django may be similar to MVC but it is not MVC. As explained here in the official django documentation faq. @adrita, I think you need may need to go review the official documentation to help you understand the concept of models, views, and templates a bit better.
diek
  • 181
  • thanks for your suggestions. will go through the documentation surely :) – adrita Jul 17 '14 at 06:04
  • Glad you got it fixed, @miraculixx gave a solid explanation. If you are on fb join the django python framework group. – diek Jul 17 '14 at 06:28
In the official Django docs https://docs.djangoproject.com/en/1.11/, it says:
Django has the concept of “views” to encapsulate the logic responsible for processing a user’s request and for returning the response. Find all you need to know about views via the links below:
Django recommends the logic to be contained within the views.
Caleth
  • 10,519
  • 35
Simon
  • 137
    That's not necessarily the same as business logic. – FirstLastname Aug 24 '17 at 17:29
    I do not agree with that interpretation of the Django documentation. Elsewhere in the Django documentation (e.g. for `Model.clean()`) it is implied a bit more explicitly that (if we simply a real-world Django project to models, templates, and views) - business logic (or at the very least, validation) belongs in the model layer. Note that I didn't include forms in that simplification, which are also acceptable. – Kye Nov 24 '18 at 10:37
