28
There are some good examples of well-documented code out there, such as java api. But, a lot of code in public projects such as git and internal projects of companies is poorly documented and not very newcomer friendly.
In all my software development stints, I have had to deal with poorly documented code. I noticed the following things -
  1. Little or no comments in code.
  2. Method and variable names are not self describing.
  3. There is little or no documentation for how the code fits into the system or business processes.
  4. Hiring bad developers or not mentoring the good ones . They can't write simple and clean code. Hence its difficult or impossible for anyone, including the developer to document the code.
As a result, I have had to go through a lot of code and talk to many people to learn things. I feel this wastes everyone's time. It also creates the need for KT/Knowledge transfer sessions for newcomers to a project.
I learned that documentation is not given the attention it deserves because of the following reasons:
  1. Laziness.
  2. Developers don't like to do anything but code.
  3. Job security. (If no one can understand your code easily, then you might not be easily replaceable.)
  4. Difficult deadlines leave little time to document.
So, I am wondering if there is a way to encourage and enforce good documentation practices in a company or project. What are the strategies to be used for creating decent documentation for the systems and code of any project, regardless of its complexity ? Are there any good examples of when minimal or no documentation is needed ?
IMHO, I feel that we should have a documentation review after a project is delivered. If it is not simple, concise, illustrative and user friendly, the developer or technical documentation engineer own the responsibility for it and be made to fix it. I neither expect people to make reams of documentation, not hope that it will be user friendly like the head first books, but I expect it to eliminate the need for hours of analysis and wasteful KT sessions.
Is there a way to end or alleviate this madness ? "Document driven development" perhaps ?
Erran Morad
  • 407
    There is another reason why there is often no proper documentation: It is very hard to write good documentation that doesn't just paraphrase the code in English, but describes *why* the code is designed/written that way. The need for this information only becomes obvious months *after* it should have been written down. – Bart van Ingen Schenau Jul 05 '14 at 06:04
    Another serious reason: many developers have English as a second language and/or or write English badly. You might just force them to write a one-liner for a method, but if you want good documentation you better be prepared to pay for it, and hire specialists to do it. – david.pfx Jul 08 '14 at 10:49
How to document code?
You already have a hint: look at how Java API is documented.
More generally, there is no unique set of rules which apply to every project. When I work on business-critical large-scale projects, the documentation has nothing to do with the one I would write for a small open source library, which, in turn, has nothing to do with the documentation of my medium-scale personal project.
Why many open source projects are not documented well?
Because most open source projects are made by people who contribute to those projects because it's fun. Most programmers and developers consider that writing documentation is not fun enough to be done for free.
Why many closed-source projects are not documented well?
Because it costs a huge amount of money to (1) write good documentation and to (2) maintain it.
  1. The immediate cost (cost of writing the documentation) is clearly visible to the stakeholders: if your team asks to spend the next two months documenting the project, it's two additional months of salary to pay.
  2. The long term cost (cost of maintaining the documentation) becomes noticeable pretty easy too to the managers, and is often the first target when they must lower the cost or shorten the delays. This causes an additional problem of outdated documentation which quickly becomes useless, and is extremely expensive to update.
  3. The long term savings (savings from not having to waste a few days exploring the legacy code just to understand a basic thing which should have been documented years ago) are, on the other hand, difficult to measure, which confirms the feeling of some managers that writing and maintaining documentation is a waste of time.
What I often observe is that:
  1. At the beginning, the team is willing to document a lot.
  2. Over time, pressure of deadlines and lack of interest make it more and more difficult to maintain the documentation.
  3. A few months later, a new person who joins the project practically can't use the documentation, because it doesn't correspond at all to the actual system.
  4. Noticing that, management blames developers for not maintaining the documentation; developers ask to spend a few weeks updating it.
    • If management grants a few weeks for that, the cycle repeats.
    • If management refuses, based on previous experience, it only increases the bad experience, since the product lacks documentation, but a few months were spent writing and maintaining it.
Documentation should be a continuous process, just like testing. Spend a week simply coding a few thousands of LOC, and getting back to tests and documentation is very, very painful.
How to encourage the team to write documentation?
Similarly to the ways to encourage people to write clean code, to do regular refactoring, to use design patterns or to add enough unit tests.
  • Lead by example. If you write good documentation, your pairs might start doing it too.
  • Do systematic code reviews, including formal code reviews targeted at inspecting the documentation.
  • If some members of the team are particularly antipathetic to good documentation (or documentation at all), discuss the subject with them privately, to understand what are the impediments which prevent them from writing better documentation. If they blame the lack of time, you see the source of the problems.
  • Make the presence or the lack of documentation measurable for a few weeks or months, but don't focus on that. For example, you may measure the number of lines of comments per LOC, but don't make it a permanent measure, otherwise, developers will start writing long but meaningless comments just to get rid of low scores.
  • Use gamification. This comes together with the previous point.
  • Use positive/negative reinforcement.
  • (See the comment by SJuan76) Treat the lack of comments as errors. For example, in Visual Studio, you can check an option to generate XML documentation. If you also check that all warnings are treated as errors, the lack of a comment at the top of a class or a method will halt the compilation.
    As for the three previous points, this one should be used with caution. I used it for a while with a particularly tough team of beginner programmers, and it ended up with StyleCop-compliant comments like that:
    /// <summary>
    /// Gets or sets the PrimaryHandling.
    /// </summary>
    public Workflow PrimaryHandling { get; set; }
which were, hm..., not particularly helpful.
Remember: nothing automated can help you pinpoint bad comments when programmers wants to screw with you. Only code reviews and other human tasks will help.
Are there any good examples of when minimal or no documentation is needed?
Documentation explaining the architecture and the design is not needed:
  • For a prototype,
  • For a personal project written in a few hours to accomplish a task, while being pretty sure this project won't be maintained any longer,
  • For any project where it is obvious, given the small size of it, coupled with the particularly clean code, that you will spend more time writing documentation than all the future maintainers exploring the code.
In-code documentation (code comments) is not needed according to some developers when the code is self-documenting. For them, the presence of comments is, except in the rare cases, not a good sign, but a sign that the code wasn't refactored enough to be clear without the need for comments.
If your project is delivered at least once per week, it's the way to go. If your project is not agile and is delivered at the intervals of six months, then do more regular reviews.
Arseni Mourzenko
  • 134,780
  • 343
  • 513
  • To 'how to encourage', I would add that many IDEs allow for notification of missing documentation as warnings. Alternatively, maybe an static analysis of the documentation can be done at the OSB (of course, that alone would not be enough). – SJuan76 Jul 04 '14 at 20:28
  • @SJuan76: Indeed. Visual Studio can even treat the lack of comments as a compile-time error. I edited my answer to add a note about that. – Arseni Mourzenko Jul 04 '14 at 20:52
  • @ArseniMourzenko - I read that we could encourage some documentation in Agile by adding stories for documentation. But, these should not block the other stories i.e. other stories definition of done, must not include completion of documentation stories. How does that sound ? – Erran Morad Jan 30 '17 at 02:59
  • @ArseniMourzenko - I'd like to add two more points to your answer. (1) In Jira etc., add a task for documentation all the time. (2) Have any documents reviewed by 2 more people & put that as a task too. That way, people will be reminded to document & will avoid writing low quality docs (due to review). If you don't prioritize it & review it, then it will become bad. I know that Amazon does a lot of docs & doc reviews, maybe a bit too much. – Erran Morad Nov 21 '20 at 18:26
I think you should make a distinction between comments and documentation. While comments are descriptive, they lack consistancy, they are scattered all over the code. Comments should never compensate for code which is not self-describing enough, instead it should hint other programmers at tricky parts.
Whether code should be documented depends on the scale of the project. Surely there are people who believe that everything should be documented, and it seems easy to justify that thought because who would dare to oppose documenting knowledge? Fortunately software development is not science, and the world doesn't collapse if the details behind your little program become obscure. Now concerning a professional software for use by many developers, yes obviously you should document your code. But if you are in the position to code on that level, then you would obviously know that.
tl;dr
If you're asking for every project to be well documented, then you're asking too much.
    `Fortunately software development is not science` Please tell me more about why you believe this. – Erran Morad Jul 04 '14 at 19:52
    @Borat - Software development is an engineering discipline, which implies that it uses the tools provided _by_ science. – Leopold Asperger Jul 04 '14 at 19:56
  • I am not asking everything to be documented. It should be just enough to give a high level overview of what a system and code does. Eg. Please tell me how to use my TV. I don't care if it uses LCD, CRT, Vaccum tubes or Solid state devices to get the job done. If a repair man wants that info, then make separate documentation for him. – Erran Morad Jul 04 '14 at 20:03
  • If you want a high level overview, then identifier names are enough. Just like the button on your TV might have an "On" label. So you are asking for low-level details. – Leopold Asperger Jul 04 '14 at 20:10
  • okay, i admit i gave a bad analogy. I cannot give you code examples from work. – Erran Morad Jul 04 '14 at 20:11
    @LeopoldAsperger: I think Borat is talking about documenting architecture and design, not methods in classes. – Arseni Mourzenko Jul 04 '14 at 20:11
  • @MainMa - Yes I think you are right, but that means that he is looking to maintain a project instead of utilizing it, that wasn't implied in the OP. – Leopold Asperger Jul 04 '14 at 20:29
  • @Leopold Asperger: "Software development is an engineering discipline...." Yeh, Na...... Proof: What profession body must you belong to be a software developer, and what qualification is required under law for you to call yourself a software developer? - if we really were engineers, this question would not have been asked and my questions would have an answer other the "None". As professionals we,a s a groups, are indeed special - in a narcissistic kind of way. – mattnz Jul 05 '14 at 05:57
  • @mattnz - Simply put, an engineer is a person who builds. Whether the object being built is tangible is not relevant. Government qualifications are meant to regulate a profession, if there are too many candidates too qualify for a certain job, then qualifications are defined to keep the pool healthy. Since the uncommon introversion trait is what characterizes most programmers, I think software development will be safe for a while. – Leopold Asperger Jul 05 '14 at 08:12
