There's lots of reasons. Eric Lippert has stated many times that the reason feature X
isn't in C# is because it's just not in their budget. Language designers don't have an infinite amount of time nor money to implement things, and each new feature has maintenance costs associated with it. Keeping the language as small as possible isn't just easier for the language designers - it's also easier for anyone writing alternative implementations and tools (e.g. IDEs) Additionally, when something is implemented in terms of the language rather than part of it, you get portability for free. If unit testing is implementing as a library, you only need to write it once and it'll work in any conforming implementation of the language.
It's worth noting that D does have syntax-level support for unit testing. I don't know why they decided to throw that in, but it's worth noting that D is meant to be a "high level systems-programming language". The designers wanted it to be viable for the kind of unsafe, low-level code C++ has traditionally been used for, and a mistake in unsafe code is incredibly costly - undefined behavior. So I suppose it made sense to them to expend extra effort on anything that helps you verify that some unsafe code works. For example, you can enforce that only certain trusted modules can perform unsafe operations like unchecked array accesses or pointer arithmetic.
Quick development was also a priority for them, so much so that they made it a design goal that D code compiles fast enough to make it usable as a scripting language. Baking unit tests right into the language so you can run your tests by just passing an extra flag to the compiler helps with that.
However, I think a great unit testing library does much more than just find some methods and run them. Take Haskell's QuickCheck for example, which lets you test things such as "for all x and y, f (x, y) == f (y, x)
". QuickCheck is better described as a unit test generator and allows you to test things at a higher level than "for this input, I'm expecting this output". QuickCheck and Linq aren't all that different - they're both domain-specific-languages. So rather than bolting on unit testing support unto a language, why not add the features needed to make DSLs practical? You'll end up with not just unit testing, but a better language as a result.
