Licensing question - am I allowed to use a GPL binary executable (.exe) in my copyrighted .bat script? Namely I want to use FART command line tool (find & replace text in files) in an install script for a proprietary product. Is such use actually static or dynamic type of linking?
Asked
Active
Viewed 477 times
Bat files execute and do not link.
Yes you can execute GPLed code from non-GPLed code. The only thing you will need to do is if you distribute FART, make sure you distribute it's source code as well. See semantic A/V for a popular example. Or many video games. As long as you give credit and don't violate the rules about distributing binaries without source your should be fine.
coteyr
- 2,420
- 1
- 12
- 14
Thanks for an answer. Is it enough to distribute only URL to the source code? – Kozuch Jul 15 '14 at 14:31
