The proper choice is using the single view with the strings stored in the appropriate localization framework for the view.
There are two main reasons for this:
It's DRY. There is one view that is used for all the languages. Consider the joys you will have when you need to change the layout on the view if you have one for each language... you've likely got English and then the FIGS set... and possibly CJK too... That's eight copies of the same view. You're going to miss one and you're going to make a mistake in another one. One view.
The industry behind localization is based on taking a file of strings and translating that file. You might have this person in house instead... either way, they aren't programers. The markup for the view itself - be it php, jsp, erb, or a chunk of javascript. You don't want to be sending them your code, and you don't want them making mistakes in translating your variables, styles, and structures (<font color="black">test</font>
becomes <fuente colorido="negro">prueba</fuente>
). You, the programmer understand what needs to be translated and what does and giving just this to the person doing the translation makes it less likely to introduce errors.
Use the localization framework. It will make it easier for you, it will make it easier for the person doing the translations.
