47
Lately I've been in the habit of "masking" Java collections with human-friendly class names. Some simple examples:
// Facade class that makes code more readable and understandable.
public class WidgetCache extends Map<String, Widget> {
Or:
// If you saw a ArrayList<ArrayList<?>> being passed around in the code, would you
// run away screaming, or would you actually understand what it is and what
// it represents?
public class Changelist extends ArrayList<ArrayList<SomePOJO>> {
A colleague pointed out to me that this is bad practice, and introduces lag/latency, as well as being an OO anti-pattern. I can understand it introducing a very tiny degree of performance overhead, but can't imagine it's at all significant. So I ask: is this good or bad to do, and why?
svick
  • 9,999
  • 51
herpylderp
  • 2,017
    It's much simpler than this. It's bad practice because I imagine your are extending the implementations of those Java basic JDK Collection. In Java, you can only extend one class, so you have to think and design more when you have an extension. In Java, use extend sparingly. – InformedA Jun 27 '14 at 19:07
  • `ChangeList` compilation will break at `extends`, because [List](http://docs.oracle.com/javase/7/docs/api/java/util/List.html) is an interface, requires `implements`. @randomA what you're imagining misses the point because of this error – gnat Jun 27 '14 at 20:38
  • @gnat It is not missing the point, I am assuming that he was extending an `implementation` ie `HashMap` or `TreeMap` and what he had there was a typo. – InformedA Jun 28 '14 at 01:31
    This is a BAD practice. BAD BAD BAD. Don't do this. Everyone knows what a Map is. But a WidgetCache? Now I need to open WidgetCache.java, I need to remember that WidgetCache is just a map. I have to check every time I new version comes out that you haven't added something new to WidgetCache. God no, never do this. – Miles Rout Jul 02 '14 at 03:20
  • "If you saw a ArrayList> being passed around in the code, would you run away screaming . . .?" No, I'm quite comfortable with nested generic collections. And you should be, too. – Kevin Krumwiede Sep 28 '16 at 17:16
6 Answers6
77
Lag/Latency? I call BS on that. There should be exactly zero overhead from this practice. (Edit: It has been pointed out in the comments that this can, in fact, inhibit optimizations performed by the HotSpot VM. I don't know enough about VM implementation to confirm or deny this. I was basing my comment off of the C++ implementation of virtual functions.)
There is some code overhead. You have to create all the constructors from the base class that you want, forwarding their parameters.
I also don't see it as an anti-pattern, per se. However, I do see it as a missed opportunity. Instead of creating a class that derives the base class just for the sake of renaming, how about you instead create a class that contains the collection and offers a case-specific, improved interface? Should your widget cache really offer the full interface of a map? Or should it instead offer a specialized interface?
Furthermore, in the case of collections, the pattern simply doesn't work together with the general rule of using interfaces, not implementations - that is, in plain collection code, you would create a HashMap<String, Widget>, and then assign it to a variable of type Map<String, Widget>. Your WidgetCache cannot extend Map<String, Widget>, because that's an interface. It cannot be an interface that extends the base interface, because HashMap<String, Widget> doesn't implement that interface, and neither does any other standard collection. And while you can make it a class that extends HashMap<String, Widget>, you then have to declare the variables as WidgetCache or Map<String, Widget>, and the first loses you the flexibility to substitute a different collection (maybe some ORM's lazy loading collection), while the second kind of defeats the point of having the class.
Some of these counterpoints also apply to my proposed specialized class.
These are all points to consider. It may or may not be the right choice. In either case, your colleague's offered arguments are not valid. If he thinks it's an anti-pattern, he should name it.
Sebastian Redl
  • 14,950
  • 51
  • "There should be exactly zero overhead from this practice" - so the deopt code in HotSpot is clever enough to handle this correctly? I was pretty sure it wouldn't - any link to support that claim? I guess the cost of a polymorphic inline cache isn't that big, but it's certainly bigger than zero. – Voo Jun 27 '14 at 22:08
  • @Voo There's probably polymorphism involved anyway for the iface -> impl lookup, don't think this brings anything new to the game. – TC1 Jun 27 '14 at 22:56
  • @TC1 Doing something like this could screw up CHA optimizations - for `Map` that's likely to fail anyhow though. Next though is that this can then easily mess with inline caches (iirc HotSpot uses 2 hot targets) and we really don't want that. It may be possible that HotSpot is clever enough to realize that no new method targets exist and alias both types, or that the inline caches fit anyhow for the planned use case (certainly a possibility), but I'd really like to hear some actual support for such a big claim.. – Voo Jun 27 '14 at 23:29
    Note though that while it's quite possible to have some performance impact, it is not going to be that horrible (missing some inlining optimizations and getting an extra vcall in the worst case - not great in your innermost loop but otherwise probably fine). – Voo Jun 27 '14 at 23:33
    This really good answer tells everyone "don't judge the decision by performance overhead" - and the only discussion here below is "how does HotSpot handle this, is there some (in 99.9% of all cases) irrelevant performance impact" - guys, did you even bother to read more than the first sentence? – Doc Brown Jun 28 '14 at 07:27
    +1 for _"Instead of creating a class that derives the base class just for the sake of renaming, how about you instead create a class that contains the collection and offers a case-specific, improved interface?"_ – user11153 Jun 28 '14 at 15:03
    Practical example illustrating the main point in this answer: The [documentation](http://docs.oracle.com/javase/7/docs/api/java/util/Properties.html) for `public class Properties extends Hashtable` in `java.util` says "Because Properties inherits from Hashtable, the put and putAll methods can be applied to a Properties object. Their use is strongly discouraged as they allow the caller to insert entries whose keys or values are not Strings.". Composition would have been much cleaner. – Patricia Shanahan Jun 29 '14 at 13:49
    @DocBrown No, this answer claims that there's no performance impact at all. If you make strong statements you better be able to support them, otherwise people will probably call you out on it. The whole point of comments (on answers) is to point out inaccurate facts or assumptions or add useful notes, but certainly not to congratulate people, that's what the voting system is for. – Voo Jun 29 '14 at 15:37
  • "missed opportunity"! Excellent way to describe this. – aaiezza Jan 31 '18 at 16:45
25
According to IBM this actually is an anti-pattern. These 'typedef' like classes are called psuedo types.
The article explains it a lot better than I do, but I'll try to summarize it in case the link goes down:
  • Any code that expects a WidgetCache cannot handle a Map<String, Widget>
  • These Pseudotypes are 'viral' when using multiple packages they lead to incompatibilities while the base type (just a silly Map<...>) would've worked in all cases in all packages.
  • Pseudo types are often to concrete, they do not implement specific interfaces because their base classes only implement the generic version.
In the article they propose the following trick to make life easier without using pseudo types:
public static <K,V> Map<K,V> newHashMap() {
    return new HashMap<K,V>();
Map<Socket, Future<String>> socketOwner = Util.newHashMap();
Which works due to automatic type inference.
(I came to this answer via this related stack overflow question)
Roy T.
  • 644
    Isn't the need for `newHashMap` solved now by the diamond operator? – svick Jun 28 '14 at 14:38
  • Absolutely true, forgot about that. I don't normally work in Java. – Roy T. Jun 28 '14 at 14:40
  • I wish languages would allow for a universe of variable types which held references to instances of other types, but could still support compile-time checking, such that a value of type `WidgetCache` could be assigned to a variable of type `WidgetCache` or `Map` without a cast, but there was a means by which a static method in `WidgetCache` could make take a reference to `Map` and return it as type `WidgetCache` after performing any desired validation. Such a feature could be especially useful with generics, which would not have to be type-erased (since... – supercat Mar 16 '15 at 21:52
  • ...the types would exist only in the mind of the compiler anyway). For many mutable types, there are two common types of reference field: one that holds the only reference to an instance which may be mutated, or one that holds a sharable reference to an instance nobody is allowed to mutate. It would be helpful to be able to give different names to those two kinds of fields, since they require different usage patterns, but they should both hold references to the same types of object instances. – supercat Mar 16 '15 at 21:55
    This is a great argument for why Java needs type aliases. – GlenPeterson Nov 10 '15 at 13:57
13
The performance hit would be limited at most to a vtable lookup, which you are most likely already incurring. That's not a valid reason to oppose it.
The situation is common enough that most all statically typed programming languages have special syntax for aliasing types, usually called a typedef. Java probably didn't copy those because it originally didn't have parameterized types. Extending a class isn't ideal, due to the reasons Sebastian covered so well in his answer, but it can be a reasonable workaround for Java's limited syntax.
Typedefs have a number of advantages. They express the programmer's intent more clearly, with a better name, at a more appropriate level of abstraction. They are easier to search for debugging or refactoring purposes. Consider finding everywhere a WidgetCache is used versus finding those specific uses of a Map. They are easier to change, for example if you later find you need a LinkedHashMap instead, or even your own custom container.
Karl Bielefeldt
  • 146,727
  • 38
  • 279
  • 479
12
I suggest you, as others already mentioned, to use composition over inheritance, so you can expose only methods that are really needed, with names that matches to intended use case. Do users of your class really need to know that WidgetCache is a map? And be able to do with it anything they want? Or they just need to know that is a cache for widgets?
Example class from my codebase, with solution to similar problem that you desribed:
public class Translations {
    private Map<Locale, Properties> translations = new HashMap<>();
    public void appendMessage(Locale locale, String code, String message) {
        /* code */
    public void addMessages(Locale locale, Properties messages) {
        /* code */
    public String getMessage(Locale locale, String code) {
        /* code */
    public boolean localeExists(Locale locale) {
        /* code */
You can see that internally it's "just a map", but public interface is not showing this. And it have "programmer-friendly" methods like appendMessage(Locale locale, String code, String message) for easier and more meaningful way of inserting new entries. And users of class can't do, for example, translations.clear(), because Translations is not extending Map.
Optionally, you can always delegate some of needed methods to internally used map.
user11153
  • 241
I see this as an example of a meaningful abstraction. A good abstraction has a couple of traits:
  1. It hides implementation details which are irrelevant to the code consuming it.
  2. It is only as complex as it needs to be.
By extending, you're exposing the entire interface of the parent, but in many cases much of that may be better hidden, so you'd want to do what Sebastian Redl suggests and favor composition over inheritence and add an instance of the parent as a private member of your custom class. Any of the interface methods that do make sense for your abstraction can be easily delegated to (in your case) the inner collection.
As for a performance impact, it's always a good idea to optimize code for readability first, and if a performance impact is suspected, profile the code to compare the two implementations.
Mike Partridge
  • 6,587
  • 39
+1 to the other answers here. I'll also add that it's actually deemed to be very good practice by the Domain Driven Design (DDD) community. They advocate that your domain and the interactions with it should have semantic domain meaning as opposed to the underlying data structure. A Map<String, Widget> could be a cache, but it could also be something else, what you've correctly done In My Not So Humble Opinion (IMNSHO) is to model what the collection represents, in this case a cache.
I'll add an important edit in that the domain class wrapper around the underlying data structure should probably also have other member variables or functions which truly make it a domain class with interactions as opposed to just a data structure (if only Java had Value Types, we'll get them in Java 10 - promise!)
It will be interesting to see what impact Java 8's streams will have on all of this, I can imagine that perhaps some public interfaces will prefer to deal with a Stream of (insert common Java primitive or String) as opposed to a Java object.
Martijn Verburg
  • 22,006
  • 49
  • 81
