Having a larger WinForms application with several classes I currently pass references to several "central" objects around to function calls.
This leads to more method parameters.
Example:
public static class Program
    private static MyCentral _central;
public class SomeController
    public object SomeFunction(MyCentral central)
        // Do something with the MyCentral instance.
Now I'm asking myself whether I should ditch this approach and instead use singletons for those central objects so that everyone can always access these objects and I do not need to pass them around anymore.
Example:
    public static MyCentral Central { get; private set; }
    public object SomeFunction()
        // Do something with the Program.Central singleton.
My question:
Are there any rules-of-thumb whether the singleton approach or the "passing objects around" approach should be prefered?
Uwe Keim
  • 347
The rule of thumb is:
Always pass around, never use the traditional singleton pattern approach.
The problem kind of solves itself if you use a dependency injection framework.
Using public statics will make testing harder, strongly couple your components, and make dependencies between your classes harder to see.
Wilbert
  • 1,703
  • And how can I reasonable handle the passing around of several of my central objects through deeply nested call graphs? (or is this an indication of bad code design?) – Uwe Keim Jun 27 '14 at 09:53
    Have a look at dependency injection frameworks - it solves exactly this problem in a very clean and elegant way. For .Net, I can recommend [Ninject](http://www.ninject.org/). – Wilbert Jun 27 '14 at 09:54
    The second rule of thumb is "always take with a pinch of salt any rule of thumb that starts 'never'." However, in this case, I would err on the side of too-strict. – pdr Jun 27 '14 at 09:58
    Where does this rule come from? In my world where I use an object oriented language, I think that there actually should be singletons. The idea with object oriented development is that you model the classes after the real world. If there is an object that is only one instance and there will only be one instance, it should actually be a singleton. Otherwise you are not using object oriented development in a right way. There are workarounds to fix the issue with "hard to test" when using the singleton pattern. However public statics for the easy of programming should be avoided. – Johan Karlsson Jun 27 '14 at 12:05
    @JohanKarlsson Sure, but you are mixing singleton (object which has only a single instance) with a singleton stored in a global object. Nothing stops you from ever instantiating a singleton class once and then passing it around, and then, if one day you need to mock or stub it for tests you are suddenly able to do it. I personally feel that the main benefit of passing around instances instead of using singletons is that it makes testing not only easier but possible. If you are not doing automated testing or your tests are big enough to not need mocking/stubbing, then the benefit is smaller. – Maurycy Jun 27 '14 at 12:17
    Singleton (the name) is very loaded because of the infamous pattern associated with it. Yes, we need objects with a single instance. No, we do not need the singleton static/global pattern. – Wilbert Jun 27 '14 at 12:20
    @MaurycyZarzycki this has been asked and answered in another question here: [Dependency Injection and Singleton. Are they two entirely different concepts?](http://programmers.stackexchange.com/q/126875/31260) (per my reading, top answer there suggests that you're right) – gnat Jun 27 '14 at 12:31
  • Yes, it is confusing with singleton pattern. But "never use the traditional singleton pattern approach" does not tell the whole story. That was my point. Maybe a clarification? – Johan Karlsson Jun 27 '14 at 12:49
Why not
    var controller = new SomeController(_central);
    MyCentral _central;
    public SomeController(MyCentral myCentral)
        _central=myCentral;
        // Do something with _central
This is called "constructor injection". The central object has only to be passed once to your controller, it can be "mocked out" for testing purposes, and if you decide later that you need to have more than one central object, it won't become a problem.
Doc Brown
  • 199,015
  • 367
  • 565
    While not using singletons because it makes testing easier gives more immediate gratification, Doc nailed the bigger reason. When all of a sudden you need that 2nd instance, which should never happen, but does. Of course that usually only happens on successful projects because who wants to expand capabilities on applications no one is using. "Developer: We'll only ever use XYZ database so singleton is the obvious choice....some time much later...Manager:We have a potential customer but they want to use ABC database. Developer:That is going to be really, really difficult. NO NEW CUSTOMER." – Dunk Jun 27 '14 at 14:13
    @Dunk: actually, using dependency injection for a single class is much easier than making a program not depend on a specific database system - there is much more to take care of than to avoid make the db connection a singleton, and such a design does not come without a cost. But I agree fully to the general point behind your comment: using DI to separate a program into independent "building bricks" (or "components") makes it easier in the long run to react to changing requirements. – Doc Brown Jun 30 '14 at 06:46
