Edit: This answer is not specifically geared toward project-specific naming, but I believe that the principle can be applied as well. In one of my applications, I have three separate VS projects which I do not separate with either namespaces nor class prefixes as a naming convention. Namespaces would be a possible way to separate the entities by project, and would be my preferred method of separation if I actually had a need for it.
In my experience in C#, namespaces exist for this very reason.
If you define a class Dog
and class Cat
, it is logical to put them in a namespace called Animals
or Housepets
(depending on your program's purpose).
It is not, however, logical to prefix the classes with what you would normally use a namespace for: e.g. AnimalCat
as a class name.
The fact that namespaces can be defined inside other namespaces means that you have a great ability to create hierarchical organization. If you use prefixes for class names, that prospect promptly disappears. Consider the following two examples:
Class Name Prefixes
public class LanguageExtendedDictionary
public SortedDictionary<string> wordList { get; set; } // quick spell-check
public SortedDictionary<string, LanguageWord> dictionary { get; set; } // full entries
public class LanguageWord
public string word { get; set; }
public string definition { get; set; }
With this, naming schemas get cluttered real fast. In any large-ish application, you might have 50+ classes. Can you imagine trying to pass around data types like SortedDictionary<LanguageWord>
? In my experience, long class names are hard to read, and harder to code down the line. Class names should (in my opinion) be as short as possible to accurately represent the entity that it is modeling.
Imagine if we had support in our application for many languages. Would you want to create a class with the name LanguageFrenchWord
to dinstinguish between that and English? I certainly wouldn't.
This method leaves no room for class organization, which is extremely important, especially in languages like C#, Java, etc.
Namespaces
namespace Language
public class ExtendedDictionary
public SortedDictionary<string, Word> dictionary { get; set; } // full entries
public class Word
You could initialize the instances like:
var word = new Language.Word(); // if declared outside of namespace
or even simply
var word = new Word(); // if declared inside namespace
This allows you to separate what entities are in what relationship, and to set them apart. These entities are grouped logically because they have to deal with language(s). This makes sense when the complexity increases. Maybe I would have a namespace for things that relate to French
, and I would add French
as a nested namespace under Language
; e.g. Language.French
With a using
statement, like using Language
or using Language.French
, you can eliminate the need to call Language.Word()
, and instead call Word()
I'll also mention that, as you see in the above example I don't need to use the prefix Language.
while inside that namespace. So in ExtendedDictionary
, I don't need to use Language.Word
as the type in in the dictionary
variable, because both entities are in the same namespace. This reduces a lot of name clutter. With the class prefix method, you can't avoid the clutter. With namespaces, it's part of the feature of the language and makes things inherently more readable.
As the complexity increases, using prefixes causes a lot of name clutter, and a huge lack of organization. There are likely lots of neat things that you can do with namespaces in C# as well that I am simply unaware of. They were created for a reason, and this is my primary use case for them. It seems like this is what your boss is trying to emulate (the behavior), so why not use the tools that are provided in the language to accomplish that?
A side note: as far as I know, the entire .NET library uses namespaces to separate classes; e.g. System.Text
, System.Threading
, etc. They seem like the appropriate structure to use!
