EDIT: I realize my answer didn't exactly answer the question, while there is no real downside, from my timing results there is no real upside either. The difference between a inline property getter is 0.002 seconds over 500 million iterations. My test case may also not be 100% accurate since its using a struct because there are some caveats to the jitter and inlining with structs.
As always, the only way to really know is to write a test and figure it out. Here are my results with the following configuration:
Windows 7 Home
8GB ram
64bit os
i5-2300 2.8ghz
Empty project with the following settings:
.NET 4.5
Release mode
Start without debugger attached - CRUCIAL
Unchecked "Prefer 32-bit" under project build settings
Results
struct get property : 0.3097832 seconds
struct inline get property : 0.3079076 seconds
struct method call with params : 1.0925033 seconds
struct inline method call with params : 1.0930666 seconds
struct method call without params : 1.5211852 seconds
struct intline method call without params : 1.2235001 seconds
Tested with this code:
class Program
const int SAMPLES = 5;
const int ITERATIONS = 100000;
const int DATASIZE = 1000;
static Random random = new Random();
static Stopwatch timer = new Stopwatch();
static Dictionary<string, TimeSpan> timings = new Dictionary<string, TimeSpan>();
class SimpleTimer : IDisposable
private string name;
public SimpleTimer(string name)
this.name = name;
timer.Restart();
public void Dispose()
timer.Stop();
TimeSpan ts = TimeSpan.Zero;
if (timings.ContainsKey(name))
ts = timings[name];
ts += timer.Elapsed;
timings[name] = ts;
[StructLayout(LayoutKind.Sequential, Size = 4)]
struct TestStruct
private int x;
public int X { get { return x; } set { x = value; } }
struct TestStruct2
private int x;
public int X
[MethodImpl(MethodImplOptions.AggressiveInlining)]
get { return x; }
set { x = value; }
[StructLayout(LayoutKind.Sequential, Size = 8)]
struct TestStruct3
private int x;
private int y;
public void Update(int _x, int _y)
x += _x;
y += _y;
struct TestStruct4
private int x;
private int y;
x += _x;
y += _y;
struct TestStruct5
private int x;
private int y;
public void Update()
x *= x;
y *= y;
struct TestStruct6
private int x;
private int y;
x *= x;
y *= y;
static void RunTests()
for (var i = 0; i < SAMPLES; ++i)
Console.Write("Sample {0} ... ", i);
RunTest1();
RunTest2();
RunTest3();
RunTest4();
RunTest5();
RunTest6();
Console.WriteLine(" complate");
static int RunTest1()
var data = new TestStruct[DATASIZE];
var temp = 0;
unchecked
//init the data, just so jitter can't make assumptions
for (var j = 0; j < DATASIZE; ++j)
data[j].X = random.Next();
using (new SimpleTimer("struct get property"))
for (var i = 0; i < ITERATIONS; ++i)
//use some math to make sure its not optimized out (aka don't use an incrementor)
temp += data[j].X;
//again need variables to cross scopes to make sure the jitter doesn't do crazy optimizations
return temp;
static int RunTest2()
var data = new TestStruct2[DATASIZE];
var temp = 0;
unchecked
using (new SimpleTimer("struct inline get property"))
temp += data[j].X;
return temp;
static void RunTest3()
var data = new TestStruct3[DATASIZE];
unchecked
using (new SimpleTimer("struct method call with params"))
data[j].Update(j, i);
static void RunTest4()
var data = new TestStruct4[DATASIZE];
unchecked
using (new SimpleTimer("struct inline method call with params"))
static void RunTest5()
var data = new TestStruct5[DATASIZE];
unchecked
using (new SimpleTimer("struct method call without params"))
data[j].Update();
static void RunTest6()
var data = new TestStruct6[DATASIZE];
unchecked
using (new SimpleTimer("struct intline method call without params"))
data[j].Update();
static void Main(string[] args)
RunTests();
DumpResults();
Console.Read();
static void DumpResults()
foreach (var kvp in timings)
Console.WriteLine("{0,-50}: {1} seconds", kvp.Key, kvp.Value.TotalSeconds);
