For comparisons / evaluations of objects of the same class(and other purposes), is it better to define a static or a non-static (is this called "dynamic" by chance?) function?
Sample code:
class student
    internal decimal medianOfMarks()
        int count = 0;
        decimal sum = 0;
        foreach(float mark in reportCard)
            counter++;
            sum += mark;
        return sum / count;
    **OR**
    internal static decimal medianOfMark(student delinquent)
        [same logic]
Let's not consider making the function a property, though parameterless, since I'd like an answer applicable to parameterized functions as well.
What are arguments pro / con each approach?
What deciding factors do exist?
I've already thought into this myself, but I don't want to bias the discussion with my opinion.
Mark
  • 373
    See here http://programmers.stackexchange.com/questions/199735/static-or-non-static – blgt Jun 16 '14 at 09:51
  • @blgt that one is more about performance, memory consumption in particular. For me this is more about which one is better style, better comprehensible and good practice. I am by far not concerned about running out of memory. – Mark Jun 16 '14 at 11:30
    Do you need access to private members? Yes? Make it a method. No? Make it static. – Doval Jun 16 '14 at 12:18
  • @Doval that's the kind of distinction-helpers I'm looking for. – Mark Jun 16 '14 at 12:38
    If you're not concerned about what's under the hood, than @Doval's comment is the alpha and the omega. **static** == no state, **non-static** == state. – blgt Jun 16 '14 at 13:18
  • Your function is called *median* but computes the arithmetic mean/average. – CodesInChaos Jun 16 '14 at 14:47
  • 1) I'd make this a method of `ReportCard`. If you need this on the student, you should forward the call to `ReportCard`. 2) You should use a generic averaging method which takes a sequence of numbers and outputs a number. Such as `Enumerable.LINQ` 3) I wouldn't use `float` on the report card. Either go with `decimal` or with integers representing fixed point numbers. – CodesInChaos Jun 16 '14 at 14:54
    I always put static members in a separate section of the source code. This makes it clear that they are completely different from non-static members. Microsoft code analysis automatically warns you if a method could be static, but is not. – Frank Hileman Jun 16 '14 at 17:25
Subjectively, I like the non-static instance method, it feels more natural. YMMV.
Objectively, the static form requires one additional parameter that feels redundant, i.e.
myStudent.medianOfMark()
vs.
student.medianOfMark(myStudent)
I'm not a C# wizard so excuse any wrong syntax details. Also, as others have commented, there are some other issues with naming, using floats, etc...
user949300
  • 8,679
  • 26
  • 35
