54
When implementing the Builder Pattern, I often find myself confused with when to let building fail and I even manage to take different stands on the matter every few days.
First some explanation:
  • With failing early I mean that building an object should fail as soon as an invalid parameter is passed in. So inside the SomeObjectBuilder.
  • With failing late I mean that building an object only can fail on the build() call that implicitely calls a constructor of the object to be built.
Then some arguments:
  • In favor of failing late: A builder class should be no more than a class that simply holds values. Moreover, it leads to less code duplication.
  • In favor of failing early: A general approach in software programming is that you want to detect issues as early as possible and therefore the most logical place to check would be in the builder class' constructor, 'setters' and ultimately in the build method.
What is the general concensus about this?
skiwi
  • 1,138
    I don't see any advantage to failing late. What someone says a builder class "should" be doesn't take precedence over good design, and catching bugs early is always better than catching bugs late. – Doval May 28 '14 at 11:50
    Another way to look at this is that the builder may not know what's valid data. Failing early in this case is more about failing as soon as you **know** there's an error. **Not** failing early, would be the builder returning a `null` object when there was a problem in `build()`. – CLo May 28 '14 at 18:46
  • If you don't add a way to issue a warning and offer means to fix within the builder there is no point in failing late. – Mark Jun 02 '14 at 12:22
Let's look at the options, where we can place the validation code:
  1. Inside the setters in builder.
  2. Inside the build() method.
  3. Inside the constructed entity: it will be invoked in build() method when the entity is being created.
Option 1 allows us to detect problems earlier, but there can be complicated cases when we can validate input only having the full context, thus, doing at least part of validation in build() method. Thus, choosing option 1 will lead to inconsistent code with part of validation being done in one place and another part being done in other place.
Option 2 isn't significantly worse than option 1, because, usually, setters in builder are invoked right before the build(), especially, in fluent interfaces. Thus, it's still possible to detect a problem early enough in most cases. However, if the builder is not the only way to create an object, it will lead to duplication of validation code, because you'll need to have it everywhere where you create an object. The most logical solution in this case will be to put validation as close to created object as possible, that is, inside of it. And this is the option 3.
From SOLID point of view, putting validation in builder also violates SRP: the builder class already has responsibility of aggregating the data to construct an object. Validation is establishing contracts on its own internal state, it's a new responsibility to check the state of another object.
Thus, from my point of view, not only it's better to fail late from design perspective, but it's also better to fail inside the constructed entity, rather than in builder itself.
UPD: this comment reminded me of one more possibility, when validation inside the builder (option 1 or 2) makes sense. It does make sense if the builder has its own contracts on the objects it is creating. For example, assume that we have a builder that constructs a string with specific content, say, list of number ranges 1-2,3-4,5-6. This builder may have a method like addRange(int min, int max). The resulting string does not know anything about these numbers, neither it should have to know. The builder itself defines the format of the string and constraints on the numbers. Thus, the method addRange(int,int) must validate the input numbers and throw an exception if max is less than min.
That said, the general rule will be to validate only the contracts defined by the builder itself.
Ivan Gammel
  • 1,226
  • I think that it's worth noting that while **Option 1** may lead to "inconsistent" checking times, it can still be viewed as consistent if everything is "as early as possible." It's a little bit easier to make "as early as possible" more definite if the variant of the builder, the StepBuilder, is used instead. – Joshua Taylor May 28 '14 at 17:55
  • If a URI builder throws an exception if a null string is passed, is this a violation of SOLID? _Rubbish_ – Gusdor May 29 '14 at 09:32
  • @Gusdor yes, if it throws an exception itself. However, from user point of view, all options look like an exception is thrown by a builder. – Ivan Gammel May 29 '14 at 17:11
  • So why not have a validate() that is called by build()? That way there is little duplication, consistency and no SRP violation. It also makes it possible to validate the data without attempting to build, and the validation is close to the creation. – StellarVortex May 31 '14 at 09:42
  • @StellarVortex in this case it will be validated twice - once in the builder.build(), and, if the data is valid and we proceed to constructor of object, in that constructor. – Ivan Gammel Jun 02 '14 at 12:10
  • @IvanGammel I did not suggest validation in the object constructor. That would be alternative 3. This is a a variant of alternative 2. – StellarVortex Jun 02 '14 at 17:14
  • @StellarVortex, then where do you want to place validate() method? – Ivan Gammel Jun 02 '14 at 17:34
  • Strongly disagree with your SRP concern that the "builder class already has responsibility of aggregating the data to construct an object". That is an Anemic responsibility. By that standard, all objects would be Anemic. – user949300 Jul 19 '17 at 15:06
  • @user949300 that's not correct statement. Builder is not anemic by the definition, since it contains business logic for constructing the object. Adhering to the SRP means that it should contain only it, leaving the validation logic to the object itself (thus, the object is also not anemic) for the reasons that I've explained. – Ivan Gammel Jul 21 '17 at 20:39
  • Ivan - please elaborate on what "business logic" there is for constructing the object if validation is excluded. Wouldn't the Builder, in most cases, just collect parameters and then call `new()`? The seems, well, anemic. What am I missing? For the record, I agree with you that the validation probably belongs in the buildee, not the builder, but I'm arguing that SRP isn't the reason. – user949300 Jul 21 '17 at 21:17
  • Ivan - assuming you come up with a good example of non-validation business logic, just edit your answer that the builder **both** aggregates data and has this logic, so SRP arguably applies, and I'll flip my downvote. – user949300 Jul 21 '17 at 21:27
  • @user949300 even if the builder just collects the parameters and then calls new(), it's already non-anemic behavior by the definition of anemic model - aggregating the data to produce something new **is** the non-validation business logic and **is** the responsibility within SRP. What really matters here is that my answer is about avoiding code duplication and code inconsistency, rather than about following SRP. I will not alter the answer, as it contains, imho, sufficient explanation with good example of business logic within the single responsibility of Builder. – Ivan Gammel Jul 22 '17 at 18:46
38
Given that you use Java, consider authoritative and detailed guidance provided by Joshua Bloch in the article Creating and Destroying Java Objects (bold font in below quote is mine):
Like a constructor, a builder can impose invariants on its parameters. The build method can check these invariants. It is critical that they be checked after copying the parameters from the builder to the object, and that they be checked on the object fields rather than the builder fields (Item 39). If any invariants are violated, the build method should throw an IllegalStateException (Item 60). The exception's detail method should indicate which invariant is violated (Item 63).
Another way to impose invariants involving multiple parameters is to have setter methods take entire groups of parameters on which some invariant must hold. If the invariant isn't satisfied, the setter method throws an IllegalArgumentException. This has the advantage of detecting the invariant failure as soon as the invalid parameters are passed, instead of waiting for build to be invoked.
Note according to editor explanation on this article, "items" in above quote refer to rules presented in Effective Java, Second Edition.
The article doesn't dive deep into explaining why this is recommended, but if you think of it, the reasons are pretty apparent. Generic tip on understanding this is provided right there in the article, in the explanation how builder concept is connected to that of constructor - and class invariants are expected to be checked in constructor, not in any other code that may precede / prepare its invocation.
For a more concrete understanding for why checking invariants prior to invoking a build would be wrong, consider a popular example of CarBuilder. Builder methods may be invoked in an arbitrary order and as a result, one can't really know whether particular parameter is valid until the build.
Consider that sports car can't have more than 2 seats, how could one know if setSeats(4) is okay or not? It's only at the build when one can know for sure whether setSportsCar() was invoked or not, meaning whether to throw TooManySeatsException or not.
gnat
  • 21,442
  • 112
  • 288
    +1 for recommending what exception types to throw, exactly what I was looking for. – Xantix Jan 13 '16 at 17:42
  • Not sure I get the alternative. It seems to be talking purely of when invariants can only be validated in groups. The builder accepts single attributes when they don't involve any other, and only accepts groups of attributes when the group has an invariant on itself. In this case, should the single attribute throw an exception before the build? – Didier A. Feb 16 '16 at 19:59
21
Invalid values which are invalid because they are not tolerated should be made known immediately in my opinion. In other words, if you accept only positive numbers, and a negative number is passed in, there is no need to have to wait until build() is called. I wouldn't consider these the types of problems you would "expect" to have happen, since it is a prerequisite to calling the method to begin with. In other words, you would not likely depend on the failing of setting certain parameters. More likely you would presume the parameters are correct or you'd perform some check yourself.
However, for more complicated issues which aren't as easily validated may be better off being made known when you call build(). A good example of this might be using the connection information you provide to establish a connection to a database. In this case, while you technically could check for such conditions, it is no longer intuitive and it only complicates your code. As I see it, these are also the types of issues which might actually happen and that you cannot really anticipate until you try it. It's sort of the difference between matching a string with a regular expression to see if it could be parsed as an int and simply trying to parse it, handling any potential exceptions which may occur as a consequence.
I generally dislike throwing exceptions when setting parameters since it means having to catch any exception thrown, so I tend to favor validation in build(). So for this reason, I prefer using RuntimeException since again, errors in parameters passed should not generally happen.
However, this is more of a best practice than anything. I hope that answers your question.
Neil
  • 22,670
  • 45
  • 76
12
As far as I know, the general practice (not sure if there's consensus) is to fail as early as you can feasibly discover an error. This also makes it more difficult to unintentionally misuse your API.
If it is a trivial attribute that can be checked on input, such as a capacity or length which should be non-negative, then you're best to fail immediately. Holding off the error increases the distance between mistake and feedback, which makes it more difficult to find the source of the problem.
If you have the misfortune of being in a situation where the validity of an attribute depends on others, then you have two choices:
  • Require that both (or more) attributes be supplied simultaneously (i.e. single method invocation).
  • Test validity as soon as you know no more changes are incoming: when build() or so is called.
As with most things, this is a decision made in a context. If the context makes it awkward or complicated to fail early, a trade-off can be made to defer checks to a later time, but fail-fast should be the default.
JvR
  • 1,184
  • So to summarize, you are saying that it is reasonable to validate as early as possible everything that could have been covered in an object/primitive type? Like `unsigned`, `@NonNull`, etc. – skiwi May 28 '14 at 12:57
    @skiwi Pretty much, yes. Domain checks, null checks, that sort of thing. I wouldn't advocate putting much more in it than that: builders are generally simple things. – JvR May 28 '14 at 15:33
    It may be worth noting that if the validity of one parameter depends upon the value of another, one can only legitimately reject a parameter value *if one knows that the other is "really" established*. If it is permissible to set a parameter value multiple times [with the last setting taking precedence], then in some cases the most natural way to set up an object may be to set parameter `X` to a value which is invalid given the present value of `Y`, but before calling `build()` set `Y` to a value which would make `X` valid. – supercat May 28 '14 at 20:55
  • If e.g. one is building a `Shape` and the builder has `WithLeft` and `WithRight` properties, and one wishes to adjust a builder to construct an object in a different place, requiring that `WithRight` be called first when moving an object right, and `WithLeft` when moving it left, would add needless complexity compared with allowing `WithLeft` to set the left edge to the right of the old right edge provided that `WithRight` fixes the right edge before `build` is called. – supercat May 28 '14 at 20:57
The basic rule is "fail early".
The slightly more advanced rule is "fail as early as possible".
If a property is intrinsically invalid ...
CarBuilder.numberOfWheels( -1 ). ...
... then you reject it immediately.
Other cases might need values to be checked in combination and might be better placed in the build() method:
CarBuilder.numberOfWheels( 0 ).type( 'Hovercraft' ). ...
Phill W.
  • 11,891
