Our team just made the switch from FogBugz & Kiln/Mercurial to Jira & Stash/Git. We are using the Git Flow model for branching, adding subtask branches off of feature branches (relating to Jira subtasks of Jira features). We are using Stash to assign a reviewer when we create a pull request to merge back into the parent branch (usually develop but for subtasks back into the feature branch).
The problem we're finding is that even with the best planning and breakdown of feature cases, when multiple developers are working together on the same feature, say on the front-end and back-end, if they are working on interdependent code that is in separate branches one developer ends up blocking the other.
We've tried pulling between each others' branches as we develop. We've also tried creating local integration branches each developer can pull from multiple branches to test the integration as they develop. Finally, and this seems to work possibly the best for us so far, though with a bit more overhead, we have tried creating an integration branch off of the feature branch right off the bat. When a subtask branch (off of the feature branch) is ready for a pull request and code review, we also manually merge those change sets into this feature integration branch. Then all interested developers are able to pull from that integration branch into other dependent subtask branches. This prevents anyone from waiting for any branch they are dependent upon to pass code review.
I know this isn't necessarily a Git issue - it has to do with working on interdependent code in multiple branches, mixed with our own work process and culture. If we didn't have the strict code-review policy for develop (true integration branch) then developer 1 could merge to develop for developer 2 to pull from. Another complication is that we are also required to do some preliminary testing as part of the code review process before handing the feature off to QA.This means that even if front-end developer 1 is pulling directly from back-end developer 2's branch as they go, if back-end developer 2 finishes and his/her pull request is sitting in code review for a week, then front-end developer 2 technically can't create his pull request/code review because his/her code reviewer can't test because back-end developer 2's code hasn't been merged into develop yet.
Bottom line is we're finding ourselves in a much more serial rather than parallel approach in these instance, depending on which route we go, and would like to find a process to use to avoid this.
Last thing I'll mention is we realize by sharing code across branches that haven't been code reviewed and finalized yet we are in essence using the beta code of others. To a certain extent I don't think we can avoid that and are willing to accept that to a degree.
