Personally, I don't think it's a good idea to use a source control version system to store the backup files, because the GIT version control is designed for data files, not for binaries or dump files like a MySQL backup dump file. The fact that you can do it doesn't mean automatically that you should do it. Moreover, your repository, considering a new database backup for each new commit, will dramatically grow, using a lot of hard disk space and the performance of GIT will get affected, resulting in a slow source control system.
For me it's fine to execute a backup strategy and have always ready a backup file when you need to restore the database when something in your code goes wrong, but source control tools aren't made to store binary data.
For these reasons, I don't see any utility in storing the backup files for day 1 and for day 2, and then seeing the differences between the two backup files. It will require a lot of extra and useless work. Instead of using GIT to store database backups when you commit new code, store the database backups in a different path, separated by date and time, and insert in your code some reference to the new database backups created for each version, using the tags, as someone already suggested.
My final note about the database backups and GIT: A database administrator, when he needs to restore a database because some data has been lost, doesn't need to check the differences between the backup file for day 1 and the backup file for day 2, he needs just to know which is the last backup file that will allow him to restore the database, without any error and data loss, reducing downtime. Indeed, the task of a database administrator is to make the data available for recovery as soon as possible, when the system, for some reasons, fails. If you store the database backups in GIT, linked to your commits, you don't allow the database administrator to restore the data quickly, because your backups are limited to points in time that you stored in the GIT repository, and to reduce the downtime of the system, because the performance of your GIT repository will be dramatically reduced having a lot of data to store.
Then, I don't recommend to store the backups using GIT, use instead a good backup software solution (there are some of them here), that will provide more granularity and will allow you to keep your data safe and secure, and making your data recovery simple and fast in case of disasters.
