Expanding the example:
You need the result of a log calculation, log(7.2), but you have only a slide rule and no computer. It takes you:
- 15s [1x] to look up the value for 7.2 in a table on your desk (L1), because you have the page of 7.1 to 7.2 photocopied.
- 3.5 mins [14x] for your secretary to go find the same thing from a book on the office shelf (L2), though this is shared with your colleagues (cores) so you might have to wait.
- 50 mins [200x] for your secretary's assistant to go find the appropriate book from the campus library (Main memory) if you don't have a copy on the office shelf.
- 9.5 years [2e7 x] for your value to be found in the national archive which involves setting up a human chain all the way to a remote mountain village (disk seek).
- 143 years [3e8 x] for your value to be found by sending a rocket to neighbouring star system and back again (packet request with 150ms round trip).
As it goes, the galactic gods are ok to wait about 250 years if you just have the 1 answer to get, but they expect to see some sign of progress (user expects a response in 250ms).
If you had been doing a few of these and thought the result was going to come out below 0.85 (allowing you to carry on with your work on that basis), when you realise it's actually 0.857 it will take you 2.5 minutes to erase all the stuff you wrote since that mistake (branch mispredict).
Should you need more than 1 value, say a lot of values from the same book:
- 43 days [5e5 x] to receive a million or so of these from your campus library sequentially; that works out to about 7.5s each, compared to 50 minutes for getting 1.
- 3.5 days to send a large request for a load of values internationally (local network request).
- 9.5 years [2e7 x] to receive a million or so of these (local network receive), assuming they have them all to hand and don't need to look in their own national archive (disk seek), which works out to about 5 minutes each.
- 29 years [6e7 x] to receive a million or so of these from the national archive sequentially; that works out to about 15 minutes each, compared to 9.5 years for getting 1.
If it seems odd that the national archive takes longer than an international request, then yes it is odd. But that's how slow hard disks are; it is quicker to ask the next machine if it has the values to hand (i.e. cached) than to scan the head to the appropriate bit of disk ready to start receiving values.
Hopefully if the metaphor isn't too tortuous, you can start to see how you might use caching, pre-fetching and so on to avoid having to ask the national archive (disk), or heaven forbid make a network request (Proxima centauri, prepare for a generational ship in several decades time). For example, if someone said 'why don't I just pre-calculate all the log results and put them on disk so I can find one if I need it', it should be pretty apparent why it might be quicker to just calculate it every time (hint: 9.5 years!), but also why sometimes it's still quicker to cache stuff for a big sequential batch (7.5s each on average from RAM (campus library) instead of say 30s to calculate).
