19
I was watching this video on the maximum and minimum values of signed integers.
Take an example of a positive signed value - 0000 0001 The first bit denotes that the number is positive and the last 7 bits are the number itself. So it is easily interpreted as +1.
Now take an example of a negative signed value - 1000 0000 which comes out to be -8. Okay, the computer can understand that it is a negative value because of the first bit but how the hell does it understand that 000 0000 means -8?
In general, how are negative signed values stored/interpreted in a computer?
gnat
  • 21,442
  • 112
  • 288
discussedtree
  • 319
    http://nl.wikipedia.org/wiki/Two%27s_complement is how binary number are stored in computers. – Pieter B May 14 '14 at 09:37
    @PieterB Maybe your computer. And a lot of other people's. For good reasons! But don't imply it's the only way. – underscore_d Apr 17 '16 at 13:18
  • Any way you like. I can think of at least 256! ways of storing (8 bit) binary numbers on computers. However **most** of those are incredibly silly. – Caleth Feb 19 '19 at 14:17
  • C doesn't specify, it's largely how the chip manufacturer decides to represent the data. C gets compiled to machine code, and it takes care not to redefine how the chip stores numbers. Same rules apply to floating point numbers. It's up to the chip manufacturer to define how they are stored. Most chip manufacturers use 2's complement, but I'm sure there are exceptions. – Berin Loritsch Feb 20 '19 at 15:03
    it seems that the question contains an error : +1 is presented using sign magnitude representation, and -8 should be 1 0001000 in this representation. – kingsjester Jun 06 '22 at 09:05
The C standard doesn't mandate any particular way of representing negative signed numbers.
In most implementations that you are likely to encounter, negative signed integers are stored in what is called two's complement. The other major way of storing negative signed numbers is called one's complement.
The two's complement of an N-bit number x is defined as 2^N - x. For example, the two's complement of 8-bit 1 is 2^8 - 1, or 1111 1111. The two's complement of 8-bit 8 is 2^8 - 8, which in binary is 1111 1000. This can also be calculated by flipping the bits of x and adding one. For example:
 1      = 0000 0001
~1      = 1111 1110 (1's complement)
~1 + 1  = 1111 1111 (2's complement)
-1      = 1111 1111
 21     = 0001 0101
~21     = 1110 1010
~21 + 1 = 1110 1011
-21     = 1110 1011
The one's complement of an N-bit number x is defined as x with all its bits flipped, basically.
 1      = 0000 0001
-1      = 1111 1110
 21     = 0001 0101
-21     = 1110 1010
Two's complement has several advantages over one's complement. For example, it doesn't have the concept of 'negative zero', which for good reason is confusing to many people. Addition, multiplication and subtraction work the same with signed integers implemented with two's complemented as they do with unsigned integers as well.
Miles Rout
  • 919
  • In the part where you say "The two's complement of an N-bit number x is defined as 2^N - x" what is the valid range of `x`? – Jack Aug 19 '21 at 07:09
  • @Jack From `-2^(N-1)` to `2^(N-1) - 1`. E.g. a 8-bit signed number in two's complement can range from -128 to +127 (inclusive). – Roel Schroeven Aug 19 '21 at 10:32
    The C Standard requires that one of four methods is used: Signed magnitude, one’s complement, two’s complement, and two’s complement without the largest negative number. – gnasher729 Aug 20 '21 at 06:26
24
There are three well known methods for representing negative values in binary:
  1. Signed magnitude. This is the easiest to understand, because it works the same as we are used to when dealing with negative decimal values: The first position (bit) represents the sign (0 for positive, 1 for negative), and the other bits represent the number. Although it is easy for us to understand, it is hard for computers to work with, especially when doing arithmetic with negative numbers.
    In 8-bit signed magnitude, the value 8 is represented as 0 0001000 and -8 as 1 0001000.
  2. One's complement. In this representation, negative numbers are created from the corresponding positive number by flipping all the bits and not just the sign bit. This makes it easier to work with negative numbers for a computer, but has the complication that there are two distinct representations for +0 and -0. The flipping of all the bits makes this harder to understand for humans.
    In 8-bit one's complement, the value 8 is represented as 00001000 and -8 as 11110111.
  3. Two's complement. This is the most common representation used nowadays for negative integers because it is the easiest to work with for computers, but it is also the hardest to understand for humans. When comparing the bit patterns used for negative values between one's complement and two's complement, it can be observed that the same bit pattern in two's complement encodes for the next lower number. For example 11111111 stands for -0 in one's complement and for -1 in two's complement, and similarly for 10000000 (-127 vs -128).
    In 8-bit two's complement, the value 8 is represented as 00001000 and -8 as 11111000.
Bart van Ingen Schenau
  • 71,712
  • 110
  • 179
The signed integers are stored using http://en.wikipedia.org/wiki/Two%27s%20complement
Then you get :
000   0
001   1
010   2
011   3
100   -4
101   -3
110   -2
111   -1
Basically it's very easy counting, you count till half the max of the signed integer. Do a +1, make it negative and start counting down.
Jack G
  • 242
Pieter B
  • 12,867
  • 40
  • 65
-2
The simple way to understand this is: For positive number we know that number is converted into binary and then stored in the memory.
For storing negative numbers:
  1. Forget the sign of the number
  2. Take the 2's complement
To find 2's complement: For example let's take 1000 0000 the starting bit indicates it is negative
1's complement
           1000 000
           0111 111
                 +1
          __________
           1000 000 ----->>this represents the number  -8
Glorfindel
  • 3,137
Akash
