This is probably a damn fool question, for which I apologise, but I can't seem to get the google syntax right to find an answer.
Imagine a Property, like this:
private int _type
public int Type
get { return _type; }
set
_type = value;
//raise an event in your chosen language or tech
CallAFunction();
Now, imagine that CallAFunction does some sort of fairly serious heavy lifting in your application, interacting with the database via a repository.
It doesn't seem unreasonable to want a unit test for this, to make absolutely sure that Type gets set to whatever you put in and to check that doing so raises the expected event.
However, setting the property with a test will call CallAFunction() which means that you're no longer really testing a "unit" of code as such, and perhaps more importantly that a very simple test for this very simple property might well require more elaborate preparation, including repository mocking, which seems huge overkill.
In some cases you could split these apart by having CallAFunction raised via the event. But that's not always the case (I'm using WPF, and the events bubble up to non-testable XAML).
What's the best way to split these two interdependent things apart?
