Basically we want things to behave sensibly.
Consider the following problem:
I am given a group of rectangles and I want to increase their area by 10%. So what I do is I set the length of the rectangle to 1.1 times what it was before.
public void IncreaseRectangleSizeByTenPercent(IEnumerable<Rectangle> rectangles)
foreach(var rectangle in rectangles)
rectangle.Length = rectangle.Length * 1.1;
Now in this case, all of my rectangles now have their length increased by 10%, which will increase their area by 10%. Unfortunately, someone has actually passed me a mixture of squares and rectangles, and when the length of the rectangle was changed, so was the width.
My unit tests pass because I wrote all my unit tests to use a collection of rectangles. I now have introduced a subtle bug into my application which can go unnoticed for months.
Worse still, Jim from accounting sees my method and writes some other code which uses the fact that if he passes squares into my method, that he gets a very nice 21% increase in size. Jim is happy and nobody is any wiser.
Jim gets promoted for excellent work to a different division. Alfred joins the company as a junior. In his first bug report, Jill from Advertising has reported that passing squares to this method results in a 21% increase and wants the bug fixed. Alfred sees that Squares and Rectangles are used everywhere in the code and realises that breaking the inheritance chain is impossible. He also does not have access to Accounting's source code. So Alfred fixes the bug like this:
if (typeof(rectangle) == Rectangle)
if (typeof(rectangle) == Square)
rectangle.Length = rectangle.Length * 1.04880884817;
Alfred is happy with his uber hacking skills and Jill signs off that the bug is fixed.
Next month nobody gets paid because Accounting was dependent on being able to pass squares to the IncreaseRectangleSizeByTenPercent
method and getting an increase in area of 21%. The entire company goes into "priority 1 bugfix" mode to track down the source of the issue. They trace the problem to Alfred's fix. They know that they have to keep both Accounting and Advertising happy. So they fix the problem by identifying the user with the method call like so:
rectangles,
new User() { Department = Department.Accounting });
public void IncreaseRectangleSizeByTenPercent(IEnumerable<Rectangle> rectangles, User user)
if (typeof(rectangle) == Rectangle || user.Department == Department.Accounting)
else if (typeof(rectangle) == Square)
And so on and so forth.
This anecdote is based on real-world situations that face programmers daily. Violations of the Liskov Substitution principle can introduce very subtle bugs that only get picked up years after they're written, by which time fixing the violation will break a bunch of things and not fixing it will anger your biggest client.
There are two realistic ways of fixing this problem.
The first way is to make Rectangle immutable. If the user of Rectangle cannot change the Length and Width properties, this problem goes away. If you want a Rectangle with a different length and width, you create a new one. Squares can inherit from rectangles happily.
The second way is to break the inheritance chain between squares and rectangles. If a square is defined as having a single SideLength
property and rectangles have a Length
and Width
property and there is no inheritance, it's impossible to accidentally break things by expecting a rectangle and getting a square. In C# terms, you could seal
your rectangle class, which ensures that all Rectangles you ever get are actually Rectangles.
In this case, I like the "immutable objects" way of fixing the problem. The identity of a rectangle is its length and width. It makes sense that when you want to change the identity of an object, what you really want is a new object. If you lose an old customer and gain a new customer, you don't change the Customer.Id
field from the old customer to the new one, you create a new Customer
Violations of the Liskov Substitution principle are common in the real world, mostly because a lot of code out there is written by people who are incompetent/ under time pressure/ don't care/ make mistakes. It can and does lead to some very nasty problems. In most cases, you want to favour composition over inheritance instead.
