I know I have quite frequently heard that C typically has a performance advantage over C++. I didn't really think anything else of it until I realized that MSVC doesn't even seem to support the newest standard of C, but the newest it supports it C99 (as far as I know).
I was planning on writing a library with some code to render in OpenGL so I could reuse it. I was planning to write the library in C since any performance increase is welcome when it comes to graphics.
But would it really be worth it? The code using the library would likely be written in C++ and I prefer to code in C++ generally.
However, if it would produce even a small difference in performance, I would likely go with C.
It may also be noted that this library would be something that I would make to work across Windows/OS X/Linux, and I would likely compile everything natively (MSVC for Windows, Clang or GCC for OS X, and GCC for Linux...or possibly Intel's compilers for everything).
I've looked around and I've found some benchmarks and such, but everything I've seen has dealt with GCC rather than MSVC and Clang. Also, the benchmarks don't mention the standards of the languages used. Anyone have any thoughts on this?
EDIT: I just wanted to share my viewpoint on this question after a couple years more experience. I ended up writing the project I was asking this question for in C++. I started another project around the same time in C as we were looking to get out any small amount of performance we could and needed the project to be linkable in C. A couple months ago, I reached the point where I really needed maps and advanced string manipulation. I knew of the abilities for this in the C++ standard library and eventually came to the conclusion that those structures in the standard library would likely outperform and be more stable than maps and strings I could implement in C in a reasonable amount of time. The requirement to be linkable in C was easily satisfied by writing a C interface to the C++ code, which was done quickly with opaque types. Rewriting the library in C++ seemed to go much faster than when writing it in C and was less prone to bugs, especially memory leaks. I was also able to use the standard library threading library, which has been much easier than using platform-specific implementations. In the end, I believe writing the library in C++ led to great benefits with possibly a small performance cost. I haven't benchmarked the C++ version yet, but I believe that it may even be possible that I have gained some performance by using standard library data structures than ones I wrote.
