public static IEnumerable<Type> GetAccessibleTypes(this Assembly assembly)
        try
#if NET40
            return assembly.GetTypes();
#else
            return assembly.DefinedTypes.Select(t => t.AsType());
#endif
        catch (ReflectionTypeLoadException ex)
            // The exception is thrown if some types cannot be loaded in partial trust.
            // For our purposes we just want to get the types that are loaded, which are
            // provided in the Types property of the exception.
            return ex.Types.Where(t => t != null);
What are differences between assembly.GetTypes() and assembly.DefinedTypes.Select(t => t.AsType())?
Original code: https://entityframework.codeplex.com/SourceControl/latest#src/Common/AssemblyExtensions.cs
null
  • 3,546
Oğuzhan Topçu
  • 181
From the MSDN documentation: "The DefinedTypes property is comparable to the Assembly.GetTypes method, except that the DefinedTypes property returns a collection of TypeInfo objects, and the Assembly.GetTypes method returns an array of Type objects."
Not terribly useful at first sight. Looking further into the documentation on TypeInfo is much more informative: "A TypeInfo object represents the type definition itself, whereas a Type object represents a reference to the type definition. Getting a TypeInfo object forces the assembly that contains that type to load. In comparison, you can manipulate Type objects without necessarily requiring the runtime to load the assembly they reference."
The reason for this is outlined in a microsoft blog post, outlining the changes to the reflection API introduced in .NET 4.5. The main difference is that the Type now no longer necessarily forces the loading of the type, and works much more as a slim handle into the type metadata, hence making introspection much lighter.
glopes
  • 176
At a minimum, the returned objects are different types, with one being an array of Types and the other being a generic IQueryable<Type>.
Here is the code from Assembly.GetTypes()
[ResourceExposure(ResourceScope.None)]
[ResourceConsumption(ResourceScope.Machine | ResourceScope.Assembly, ResourceScope.Machine | ResourceScope.Assembly)]
public virtual Type[] GetTypes()
    Module[] m = GetModules(false);
    int iNumModules = m.Length;
    int iFinalLength = 0;
    Type[][] ModuleTypes = new Type[iNumModules][];
    for (int i = 0; i < iNumModules; i++)
        ModuleTypes[i] = m[i].GetTypes();
        iFinalLength += ModuleTypes[i].Length;
    int iCurrent = 0;
    Type[] ret = new Type[iFinalLength];
        int iLength = ModuleTypes[i].Length;
        Array.Copy(ModuleTypes[i], 0, ret, iCurrent, iLength);
        iCurrent += iLength;
    return ret;
Adam Zuckerman
  • 3,715
    [`DefinedTypes`](https://msdn.microsoft.com/en-us/library/system.reflection.assembly.definedtypes.aspx) is an `IEnumerable` not an `IQueryable`. – CodesInChaos May 15 '17 at 09:59
